Neon Radiator
Does anyone have a part number for the small dodge neon radiator. I ordered one from my local parts store and it was a long version. They said this is the only size that they have. You can't really specify the No AC and manual tranny on their computer, but they have single or dual over head cam. Any actual part number pls.
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
95-99 (older body style) NON-AC manual transimssion neon, i don't know the part number. you will need a filler neck as the radiator hasn't one installed. summit or other suplliers will have that.
good luck
try the dodge dealership, they might be able to give you the part number (i actually read the original post
stan
[Modified by 90crxsi, 12:10 PM 10/3/2002]
good luck
)stan
because neon radiators are tiny and free up space for turbos. they also use one of the stock bottom mounts. Ask jared, he may know.
Well, the radiator I ordered only goes along half the radiator support.
have you tried the junkyards?
here is the inline hose filler you will need, at least this is what i am told...
http://www.jegs.com/cgi-bin/ncommerc...96&prmenbr=361
bringing back from the dead,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustChou »</TD></TR><TR><TD CLASS="quote">Nobody's had any issues with this rad, overheating, etc? Seems like it's a good mod...</TD></TR></TABLE>
wondering this also
wondering this also
yea, i read over that site, but it didn't really say how efficient the neon rad was for cooling. i'm assuming that it doesn't do as good of a job as an EG radiator since it is smaller, but has anybody had consistent problems with overheating on this neon radiator? if so, what is your setup, where do you live, and what were the conditions when it overheated (long drive, drag racing, etc.)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw »</TD></TR><TR><TD CLASS="quote">Just get a Flodyne, small, good, and they just love having turbos. That will be what i use when my turbo goes on in 2 months</TD></TR></TABLE>
Which fluidyne fits an EF w/ a turbo? They don't make a Neon half size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith P »</TD></TR><TR><TD CLASS="quote">
They don't make a Neon half size.</TD></TR></TABLE>
look at the pictures above. it is made but, i can't seem to find any aftermarket manufacturers though.
C&R also makes a nice half-wide radiator that is designed to bolt into an EF. http://www.exospeed.com sells them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fusion210 »</TD></TR><TR><TD CLASS="quote">What you guys need is the basemodel radiator. Only in 1995 neons afaik.
As was said, no a/c.</TD></TR></TABLE>
this rad is so thin
use the EG/Ek automatic rad
this rad is so thin
Nah, doge just had an issue with the headgaskets blowing every 10 miles in those neons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi »</TD></TR><TR><TD CLASS="quote">fluidyne makes a half wide radiator for the crx. like a eg one but the right hieght to fit in the crx</TD></TR></TABLE>
They do? Thats not what they told me..
what?
http://cgi.ebay.com/ebaymotors...ZWDVW
part number : FHP11-88CRX.5
summit also carries it, just search that part number
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WuShu »</TD></TR><TR><TD CLASS="quote">because neon radiators are tiny and free up space for turbos. they also use one of the stock bottom mounts. Ask jared, he may know.</TD></TR></TABLE>
Some civics have small radiators. Dont remember the exact model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi »</TD></TR><TR><TD CLASS="quote">what?
summit also carries it, just search that part number</TD></TR></TABLE>
Fluidyne told me that was a EG radiator with special brackets.. Were they wrong? Is it the right height? Can any one confirm this?
Thanks!
Thanks!
