Please identify this part - rear washer - picture included
As some of you know, I did a successful glasstop roof install in my LHD canadian CRX SI.
Second time washing the car today and I noticed some water on my rear seat (yup)
I started to panic thinking I had a leak, but then I found the hole that let the water in.
On the rear roof brace between the hatch and the roof glass, there is an empty hole, and I have a piece that I suspect was removed from the hole.
It's a black plastic/rubber neck that has a 90 degree bend, and has washer hose attached to the end.
My old sunroof setup had the washer nozzle in the rear part of the sunroof roof skin, now that I have a glass roof, obviously this is no longer the case.
From what I have seen from pictures of real glasstop crx's is that the rear washer sprayer is in the hatch.
Can anyone confirm that this is the case?
can anyone tell me if there is a way I can drill a hole somewhere in my hatch to add a rear washer sprayer.
Or should I just simply plug the hole and run with no washer sprayer in the rear.
I have no rear wiper at the moment, I'm keeping my eye open for a jdm rear wiper and motor to clear the sir rear spoiler.
So if you have any info on this, let me know.
Thanks,
and if you haven't seen the thread and want to see the glasstop install process that I took, go here:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/project-thread-turbo-dan-sir-front-end-crx-how-installing-itr-wheel-1953144/
That's the piece that came with the glass top.
I know where the brown washer end plugs into, but what plugs into the end of the black piece?
b18c1vtecdc2
Feb 11, 2011 09:23 PM
