1991 Honda Prelude A/C doesn't blow cold.
Old Jun 23, 2011 | 09:02 AM
Spinks's Avatar
Default 1991 Honda Prelude A/C doesn't blow cold.
1991 Honda Prelude. The electric vent selector broke recently so it only blows from the defroster. I don't know how to fix that or where the unit would be to replace.
Wait there's more.
The A/C doesn't blow cold. It blows slightly cooler than what's outside. Like .01 degrees cooler. It might just be in my head. How do I make it cold? It's got an R12 port (I think). The R134a port is a lot bigger than mine. Mine is small. But enough about my *****, the valve on the cold pipe (or what I think is the cold pipe) is smaller than the sleeve cap on the R134a can. The other pipe has a valve equally as small. Can I charge it? And how? And how do I fix the vent selector?
Old Jun 23, 2011 | 12:08 PM
IAluder95's Avatar
Default Re: 1991 Honda Prelude A/C doesn't blow cold.
you can charge it. id personally take it somewhere to have it done. its cheap to do. youll have to buy the old freon. i believe could be wrong.
the electric problem is behind the dash. the unit itself is probably the problem. just undo the front and pull it out like a cd player.
Old Jun 25, 2011 | 03:41 PM
Spinks's Avatar
Ok thanks!
Immortal-Prelude
Jan 15, 2007 06:21 PM
PIBBSTER
Oct 17, 2005 03:24 PM
TheSwift1
Aug 24, 2003 04:29 PM
Krypto
Sep 9, 2002 12:37 PM
