Weird noise coming from d/s wheel
Old Jun 22, 2011 | 03:32 PM
2gnarly's Avatar
Default Weird noise coming from d/s wheel
Since Monday I've heard a weird noise coming from my driver side wheel. (at least that's where it sounds like it's coming from) The noise sounds like a screeching noise like where your brake pads are completely worn and you hit the brake, but it makes the noise while driving. It actually stops when apply certain pressure on the brake pedal, but then starts back up when I get going again. I'm not very knowledgeable when it comes to diagnosing problems so I appreciate any help I get.
Old Jun 22, 2011 | 03:48 PM
fcm's Avatar
fcm
Old Fart
Default Re: Weird noise coming from d/s wheel
Most likely the brake pad "telltail". [wear indicator]... http://www.google.ca/imgres?imgurl=h...ed=0CDcQ9QEwBg
Time to replace pads. 94
Old Jun 25, 2011 | 03:29 PM
boostedbatch's Avatar
yeah, does sound like the brake pad wear indicator. but if its more of a whining maybe a wheel bearing. Sometimes it could be as little as your dust shield for your brakes is a little bent, and its rubbing on your rotor.
Hope it helps!
Boosted.
Old Jun 25, 2011 | 10:47 PM
boosted28's Avatar
I had the same problem today,I heard brakes scraping but my breaks are good so it might be the WB.
So check your' pads and if they look ok it could be time to get a bearing pressed.
anthony
Old Jun 26, 2011 | 07:03 AM
Lowkey_kev's Avatar
Also 1.Check the Brake dust plate common missed problems for brake pads.
Old Jun 26, 2011 | 09:43 AM
fcm's Avatar
fcm
Old Fart
Ditto that ^^^
Also make sure the telltale is not bent in to far, I have seen that more then a few times. 94
HC4
Honda CR-V & Element
Jul 4, 2019 05:45 AM
jweller
Mar 9, 2015 04:48 AM
lazychina
Aug 20, 2008 05:45 PM
suspirocrx
Nov 17, 2007 11:56 AM
