99 Accord - Keyless Remote on eBay - Help Please
Hi Everyone,
My 99 Accord V6 has only one Remote and one Key, working fine, now I want to buy one extra, used EOM Remote on eBay - My question is can I program my existing remote plus other one at the same time? If yes, please tell me how?
Thank you in advance for your help...
Danny
Danny
If you had a Mazda you would be screwed - you must have two working remotes to program a third. If you only have one you have to pay the dealer for the labor to do it which is, from what I've heard, an hour of labor.
Anyway, that's Mazda. Honda isn't that strict, here are the programming instructions:
http://www.handa-accessories.com/crv/KEYLESSPROG.pdf
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by “II” on the ignition bezel so the dash lights come on, then within 5 seconds press the “Lock” button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by “I” on the ignition bezel – dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) – each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to “ON”, press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will “pop”.
Check out the link below to make sure you get the correct remote for your car:
http://www.tegger.com/hondafaq/misc/98-011.pdf
240SXFORUMS.COM
Mar 3, 2003 10:20 PM
