Can I use b16a2 engine harness on 94 CX hatch with swap?
Old Jun 22, 2011 | 01:40 PM
Mad-Mike's Avatar
Default Can I use b16a2 engine harness on 94 CX hatch with swap?
Finally got my motor swapped into my 94 civic CX hatch and all I really have to do is the wiring. I swapped my b16a2 motor in the hatch and was wondering if I can use the b16a2 engine harness? I noticed that on the driver side firewall plug is different but can I get a converter? I have a ecu jumper but I am having trouble getting some of the plugs to connect to the hatch. I am pretty much on a budget.
Old Jun 23, 2011 | 04:07 AM
94EG8's Avatar
Seagull Management
Default Re: Can I use b16a2 engine harness on 94 CX hatch with swap?
No you can't. Use a '96 - '97 Del Sol Vtec harness or one from a '97 - '99 ITR. If you can't find either of those any other '96 - '99 Integra harness will work with some slight modification.
12three
28
Mar 27, 2011 11:55 AM
candyman206
Oct 31, 2008 06:46 PM
pootie.teng
Feb 12, 2004 01:16 AM
pootie.teng
Feb 11, 2004 01:59 PM
