Hard to shift!!
Old Jun 21, 2011 | 09:37 PM
spoon.ef9's Avatar
Default Hard to shift!!
Im looking for a new car at the moment and found a good deal on a 94 acura integra rs. Car needs some paint but runs good the only thing is when I shift into ANY gear it takes alot of effort(I MEAN LOTTTSS). The seller says he hasnt driven the car since march and that it may be because of that..but I highly doubt it. Im thinking it could possibly be fluid or something???
Old Jun 21, 2011 | 09:49 PM
Doofus's Avatar
Default Re: Hard to shift!!
Check the fluid in the clutch master cylinder first. It's on the firewall near the brake master cylinder.
Old Jun 21, 2011 | 10:13 PM
spoon.ef9's Avatar
so just check to see if its @ the right level iguess
Old Jun 21, 2011 | 11:54 PM
JDMxTai's Avatar
Lift front end so front wheels are off the ground and put car in first keep the clutch to the floor see if the wheels move.
Old Jun 21, 2011 | 11:56 PM
Katastrophic's Avatar
b4 even doing that have the car off and stopped and try shifting without anything
if your feeling lazy you can always stop on a flat street put it in gear and try and push it (not recommended but....)
Old Jun 22, 2011 | 05:35 AM
spoon.ef9's Avatar
havent tried jacking it up and spinning the wheels but while the car if off its the same..no grinding or noise but it feels similar to pushing a stick back and forth while stuck in super thick mud..if you can imagine that lol
Old Jun 22, 2011 | 07:56 AM
lovelove's Avatar
First thing first, if it's shifting hard then it could possibly low on fluids. Second, check the slave cylinder. That could be the reason why. Third and last is the clutch may have seen it's end of life if it's shifting hard or won't even shift at all when the car is turned on.
Old Jun 24, 2011 | 08:15 AM
cletus11's Avatar
I had the same problem in my 98. I checked the clutch master cylinder yesterday and it was low. I added some fluid and the shifting got better. I think that my clutch master and slave cylinder need to be replaced soon. Does anyone know if the Integra master and slave cylinders are the same as a Civic?
Old Jun 24, 2011 | 08:21 AM
vrrodri's Avatar
you can always check the part numbers online and compare them to see if they are the same...
Old Jun 24, 2011 | 12:41 PM
fergs96integra's Avatar
lay down and look at the fire wall inside the cabin right where the clutch rod goes threw the firewall, see if it is damp or wet. If so the master cylinder is bad. Also checking fluid level will tell you that something is wrong if it is low. Wont get low unless there is a leak.
Old Jun 28, 2011 | 07:33 AM
cletus11's Avatar
I changed my trans fluid over the weekend and the shifting got easier and smoother. The clutch hydraulics are next.
Old Jun 30, 2011 | 06:00 AM
::ek-4::'s Avatar
The reason why it won't work is because...... "Granny shifting, not double clutching like you should!!!!"
Not double clutching like you should
Old Jul 8, 2011 | 08:29 AM
cletus11's Avatar
I replaced my clutch master and slave cylinders and the shifting became much easier at lower RPMs. However, shifting is still difficult at higher RPMs. I am not ready to change my clutch because it doesn't slip or feel bad. Could worn motor and transmission mounts make shifting more difficult? Mine mounts are just about done.
Old Jul 8, 2011 | 08:39 AM
8dxhatchy8's Avatar
i did the same thing..it was my clutch, it was my clutch, it was so warn out the springs were falling out and pieces were broke off..replaced it and it shifts like butter now..
13BT
14
May 29, 2010 09:02 PM
mattmw88
Nov 15, 2006 09:28 AM
scrap1ngsr
Apr 5, 2006 10:41 AM
Mt3c
Mar 3, 2002 12:38 AM
