ZC Oil Change
Did a search, found no oil change information specific to the ZC. Just need to know how much oil to use. I've got a nice oil filter and 4 quarts of semi synthetic 10w-30. How much of the oil should I use? TIA
Justin D. Fender
Justin D. Fender
if u dont know the quantity, do this.,... normally a Honda 1.6L engine uses about 3.8q of oil.... why dont u pour 3 quarts.... check the stick,... if u need more add..... check again..... repeat process until u get to the fill mark.,.... then u check how much oil u used...... theres no science on this,,,,good luck
Thanks, I'd rather just pour in a set amount, but I can actually do a little work. Should I replace the oil filter and oil plug before putting the new oil in?
Justin D. Fender
Justin D. Fender
DesiDez
Jul 7, 2003 06:01 PM
