New 04 EX clutch kit slipping
My throw out bearing faled last week so i replaced the clutch pressure plate and flywheel but now the clutch is slipping bad. I noticed the clutch pedal felt extremly light/soft but got a little stiffer on its own. what am I missing? fluid is full. I read somewhere there are issues with the pedal adjustment and bleeding the slave but i'm not sure. anyone have any suggestions?
Have you bled out the system checking for any air bubbles? also when you installed the new clutch did you wipe down the flywheel pressure plate of any grease? Also trying adjusting the pedal maybe its not fully releasing. but if it is a new clutch sounds like it just needs to be bled.
Thanks in advanve HT
Smcneal1970
Jun 11, 2018 06:54 AM
Scotty_Bughatti
Transmission & Drivetrain
Aug 11, 2014 11:55 AM
