What is this noise???
Old Jun 21, 2011 | 01:07 PM
hondacrx2's Avatar
Default What is this noise???
Ok I have a 99 Cbr f4. I had a cam chain tensioner put in and oil change. Now it makes this tapping noise. It only does it about every other time I start it up cold. And its not right when it starts it like a min or two after and when the temp gauge is right above the C. So it's not a knock. Also it goes away when it's warmed up so I have no clue what it is. Bike only has 5k on it so it's not valves. Any idea's? Here is a link to hear it. Listen closely. Thanks http://www.youtube.com/watch?v=7a0Yp...e_gdata_player
Old Jun 21, 2011 | 04:30 PM
rd91sib18c5r's Avatar
Default Re: What is this noise???
Sounds like valves, does it go away when fully warmed? I wouln't worry to much.
Old Jun 21, 2011 | 05:30 PM
hondacrx2's Avatar
Yes it goes away when warm but it makes the sound alittle after start up not right away so I didn't think valves. Plus it doesnt call to check valve lash till like 12k. And it's only at 5k so idk. But if I can't figure out anything else I'll have them check. I was wondering if maybe the tensioner was put in wrong or something.
Old Jun 22, 2011 | 03:28 AM
"A"'s Avatar
"A"
Does the sound go away when you pull the clutch in?
Old Jun 22, 2011 | 07:00 AM
scartail's Avatar
Oil changed with the same brand and weight?
Old Jul 4, 2011 | 10:37 AM
hondacrx2's Avatar
Same weight oil was used and I used what manual recommended. Also when the engine is revved the noise doesn't get louder. Also when the clutch is pulled in the noise is still there. I asked to local shop and they said it's normal cbr's especially that model make engine noise from the timing chain. And I know it's in good shape and so are the chain guides. And the tensioner is new. I was hoping someone on here would have this same model bike and be able to comment.
HeLLa iLL2ndGen
Aug 12, 2010 01:22 PM
Downs
Honda Motorcycles
Apr 7, 2007 08:38 PM
EF7
Honda Motorcycles
Oct 28, 2005 11:12 AM
Blownbimer
Honda Motorcycles
Oct 2, 2005 05:42 AM
beefyib123
Jan 23, 2003 06:49 PM
