Help Tach and Speedo Crazy
Old Jun 21, 2011 | 09:35 AM
mattyp1020's Avatar
Default Help Tach and Speedo Crazy
im new to the site but basically im having a problem i cant solve my tach and speedo go crazy while im driving when i wop motor buckles installed a brand new dizzy still acts up im thinking its the vss people telling me could be grounds any help please
Old Jun 21, 2011 | 11:45 AM
1ls/vtec's Avatar
Default Re: Help Tach and Speedo Crazy
sounds like speed sensor, my buddies Prelude had the same issue
Old Jun 21, 2011 | 12:30 PM
mattyp1020's Avatar
thats what im thinking im looking around for one hopefully i find one soon and fixes the problem
Old Jun 21, 2011 | 02:13 PM
TOO MUCH TORQUE's Avatar
when the tach goes jumping around, the ignitor in your dizzy is failing. buy oem ignitors..theyre a bit pricey though
check your grounds...should read the same as battery terminals
Old Jun 21, 2011 | 02:30 PM
mattyp1020's Avatar
realy cus i just bought a brand new dizzy put it in swapped clusters swapped speed sensors my buddy loaned me but it was from a d series will it still work i checked every sensor on the vehicle still nothing ..?
Old Jun 21, 2011 | 02:31 PM
mattyp1020's Avatar
i also upgraded to 4 gauge ground wires even added one to the throttle body
Old Jun 21, 2011 | 03:39 PM
thewrai6th's Avatar
Check the ground on the transmission side. I had a bad connection there, it caused my speedo and temp gauge to go crazy. It also burned out my main relay.
Old Jun 21, 2011 | 07:16 PM
mattyp1020's Avatar
Ill check that one a buddy of mine told me it could also be a bad Tps ..?
Old Jun 22, 2011 | 05:38 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Normally this is an igniter issue. Since you did swap in an entirely new Dizzy, I would say you SHOULD be ok. For giggles, have you also checked plugs and wires?
I would check and then double check your ground on the thermostat housing, clean it and reinstall it.
b20acura
Jan 14, 2012 01:02 AM
civic08
Feb 28, 2008 09:22 PM
WhiteGsrBeater
Jan 21, 2008 01:08 AM
roycivic92
10
Jan 21, 2005 03:58 PM
monkey_civic owner
15
Mar 16, 2003 01:43 PM
