GS-R Build All Motor
Old Jun 20, 2011 | 10:48 PM
S1LENT94D00R's Avatar
Default GS-R Build All Motor
I'm building the original motor out of my 94 Integra sedan. It's a B18C1. Here is a list of the parts I have. The head has already been assembled.
PR3 head- full port and polish, 5 angle valve job, milled
Ferrera flat face valves with bronze valve guides
Brian Crower dual valve springs and titanium retainers
Brian Crower 63403-2 cams
AEM tru time cam gears
AEM fuel rail
Blox intake manifold- ported runners
Blox FPR and guage
ARP head studs
Wiseco 12.5:1 81.5mm pistons w/ rings
Probe H-beam rods w/ ARP rod bolts
I plan on running E85, I'm still waiting on a few more parts to take it to the machine shop. I'm going to be using the stock crank. I'm looking for a new crank pulley (harmonic balancer). I've heard bad things about the N1 on 1.8+ liters. Any suggestions?
Old Jun 20, 2011 | 11:11 PM
igorka_91's Avatar
Default Re: GS-R Build All Motor
Stout build. What head gasket will you be running on this puppy? I would personally run a 89mm ls crank if i were to build my b series over again.
GL
Old Jun 21, 2011 | 02:08 AM
anothersickhatch's Avatar
stock crank pulley. that is my suggestion.
Old Jun 21, 2011 | 10:12 AM
GL
I plan on going OEM for most of my gaskets, I originally wanted to runt that crank but got a really good deal on the rods.
Any reasoning? I don't plan on running ac or ps.
Old Jun 21, 2011 | 10:23 AM
igorka_91's Avatar
Nice nice. Keep us updated.
Simple. Look at the ctr/n1 crank pulley and look at a gsr/ls/b20 crank pulley. It has no harmonic dampening at all. Like i have said before to a member on here. Take it off/do not run it before your oil pump takes a random **** at a random rpm.
Old Jun 21, 2011 | 11:54 AM
94eg!'s Avatar
#1 Super Guy
Loved
The Type R has a special harmonic damper that protects at higher rpm (part #13810-P73-J01 for $146). Or you can go with ATi for a racing/expensive alternative.
Old Jun 21, 2011 | 04:18 PM
Thanks I will check into both of them. I was looking at the Fluidampr ones. I've heard negative things about them at higher rpm's.
Old Jun 21, 2011 | 04:20 PM
I understand that part. but why would I run the stock pulley over a different one?
Old Jun 21, 2011 | 04:29 PM
why would you run an aftermarket pulley over a stock one? what is your reasoning?
Old Jun 22, 2011 | 06:25 AM
94eg!'s Avatar
#1 Super Guy
Loved
There's nothing an N1 pulley can accomplish that a lightweight flywheel can't. Your better off running a lightweight flywheel WITH a harmonic damper.
lukenordman
Nov 27, 2013 05:05 AM
ne3ek
16
Aug 7, 2006 01:30 PM
ITR-00-1457
Oct 19, 2004 06:09 PM
dj_seloe
Aug 26, 2004 07:16 AM
