Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire rubbing
Old Jun 20, 2011 | 08:40 PM
Slayerzero's Avatar
Default Tire rubbing
Would a 07 Honda civic ex be able to fit 18's with a tire size of 225/45/18? Thanks for any help. And no suspension mods all stock no drop and would the fenders have to be pulled or rolled.
Old Jun 21, 2011 | 12:09 PM
TunerN00b's Avatar
Default Re: Tire rubbing
Without listing the offset of the wheels, how do you expect anyone to be able to answer as to whether they'll rub or if the fenders need to be pulled/rolled?
Those tires are way too big for your car. 215/40-18 would be the correct size for 18" wheels.
Old Jun 22, 2011 | 08:20 PM
Slayerzero's Avatar
Thanks for the info but yah i wish i could get the info so easy. Its for my cousins car and he isn't completely into cars to learn all that stuff so sometimes he doesn't even know himself what he would like to do is take the tires from his old rims. He was hoping they would fit whatever new rims he decides to buy so there is no set offset at the moment. The lug pattern is different so he cant use his old rims but they were 18s and the tires he had on them were perfectly new. So he wanted to get new rims that would fit the tire but wasn't sure if they would rub or not with the set up but thanks again.
Old Jun 24, 2011 | 09:15 AM
bee guz's Avatar
I had 225 40 18's on my 06 si with hfp wheels there wasn't much room to go bigger.
<------------ in the pic
Old Jun 25, 2011 | 12:03 AM
K5^'s Avatar
K5^
Brand New
Double check the aspect ratio, 45 on R18 may run into issues. Conventional specs for 8th gen civics are 225/40.
Old Jun 25, 2011 | 08:33 AM
Slayerzero's Avatar
Thanks for the help guys your right k5 the tires are 225/40/r18 my mistake I had my bro in law double check. So now the offset what is the offset on your rims bee guz and did u have to adjust camber or roll/pull fenders or get spacers or anything? Once again thanks so much u all have been very helpful so far. What is the highest recommended offset if it is known.
Phailzilla
Jul 19, 2013 06:08 PM
HatchSpeeD
Apr 3, 2009 09:00 PM
brzrkr
Sep 18, 2008 11:03 AM
KOREAN
May 7, 2004 08:45 PM
ryand16y8
Mar 13, 2002 07:06 PM
