anyone with a 90-91 help
Old Jun 20, 2011 | 08:29 PM
gnxpro24's Avatar
Default anyone with a 90-91 help
I pulled an EX harness from a 90 civic and my car is an 89. I dont know if this is a multipoint thing (si or EX) or if its from all 90-91s. what plug is this? it plugs into the engine harness and only one of the wires from it runs a different way which is to the relay for the fan. its a small square plug where you plug the engine harness into the main harness
Old Jun 21, 2011 | 03:12 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: anyone with a 90-91 help
That is all 88-91' MPFI harness's that I am aware of. The extra plug is for the extra wires for a MPFI distributor and if I remember right the power for the injectors?
Old Jun 21, 2011 | 04:06 AM
crx_si-r's Avatar
why are you worried about it if your car will now be MPFI? im assuming you grabbed the matching engine harness.
every time you attempt something you run into problems because you forget to LABEL. or you have a really bad memory.
Old Jun 21, 2011 | 10:28 AM
gnxpro24's Avatar
I do have a horrible memory but I know what it plus into because I have the corresponding engine harness. Im just trying to stay informed on anything that changes between the two wiring harnesses
Old Jun 21, 2011 | 11:32 AM
gnxpro24's Avatar
apparently the resistor box plug was cut off and now I need to solder a new one on. does it matter which wires go where to the resistor box plug? cause theyre all red with a black stripe
Old Jun 21, 2011 | 11:46 AM
DO IT ON ALL FOURS
Nope... Doesn't matter on which wires go where (aside from input and output of course).
Old Jun 21, 2011 | 12:07 PM
gnxpro24's Avatar
thanks. appreciate the help
JDMEMone
Mar 26, 2015 07:25 PM
sonic47
13
Feb 10, 2010 03:23 AM
Keith P
Jun 12, 2005 04:33 PM
elmalouno
Apr 26, 2004 02:35 PM
wickedEFguy
Oct 29, 2003 09:10 PM
