Front wheel bearing help
Try rotating the sensor 90* to break it free from the corrosion. Rotate back and pull out. I would not pry on it if you plan on keeping it as you can snap it off. When reinstalling slather the outside and inside of the bore with anti-seize or grease.
Thanks i have it in oil now i will try this in the morning.
ColeCooper90
Jan 4, 2019 12:35 PM
