FS: Fully Built 1999 Honda Civic B16a Turbo ready motor
Selling a fully built B16a that is turbo-ready
Block and Head is fully assembled but never been ran after motor was built
Motor only has 56k miles on it
Labor has been done at AEBS motor sports in Miramar, CA
I have all receipts for all work done
Project never finished, decided to go Kswap
No Tranny included
$3000 obo
Here are the parts and labor I've spent on this motor:
Pauter rods - 720
Ross Racing pistons (8.5:1) - 650
3-angle valve job - 275
Cometic head gasket - 85
(8) REV stainless steel intake valve - 200
(8) REV stainless steel exhaust valve 1mm over - 200
REV valve spring - 235
REV titanium valve spring retainers - 132
(2) AEBS T-Sleeve single flat - 200
(2) AEBS T-Sleeve double flat - 200
AEBS final bore/hone 83mm - 200
AEBS main studs - 132
AEBS head studs - 132
AEBS O-Ring - 200
oem acura bearings main-rod-thrust - 214
oem acura itr oil pump - 116
oem honda water pump - 103
oem honda upper gasket set - 227
oem honda lower gasket set - 53
Labor:
blueprint / balance - 700
machine block press fit/surface - 655
Before Rebuild:
No Tranny included
$3000 obo
Pauter rods - 720
AEBS O-Ring - 200
Labor:
Before Rebuild:
theinfamouskonrad
Feb 3, 2007 11:37 AM
VNTEC
Jan 11, 2006 05:30 PM
