1999 Accord does not cold start
Old Jun 20, 2011 | 09:45 AM
mextera's Avatar
Default 1999 Accord does not cold start
My sons accord is having a hard time with cold starts when I last had it started we had check engine light read and found that the IAT sensor was send a code. Is this my likely prblem or is there something else I chould look at. 187K
Thx
Rod
Old Jun 20, 2011 | 05:41 PM
poorman212's Avatar
Default Re: 1999 Accord does not cold start
I would always follow the codes first.....then if there is still an issue and there are no codes, suggestions/ideas will come.
Old Jun 28, 2011 | 06:34 PM
mextera's Avatar
Thx i did get the code read at Autozone and they said a IAT sensor. I replaced the sensor engine started and since I had disconnected the battery the code did not appear when repalced. The car started but was still a little slow to start. No check engine light after four days the light retruned and the same code IAT sensor.
What should I check next? When I replaced the sensor the inside of the opening did feel a little dirty.
I have a new bottle of RXP hopeing that may help clean the intake.
Thanks for the help.
Rod
Old Jun 28, 2011 | 10:26 PM
holmesnmanny's Avatar
I would drop some isoheet in the fuel tank and replace the fuel filter first.
Old Jun 28, 2011 | 11:14 PM
slomofo's Avatar
GDD Member
Does it run rough for the first two minutes after the cold start?
jayrod7
Jan 21, 2010 01:45 PM
bstaralways
Sep 4, 2007 02:51 PM
ghomer
Nov 4, 2006 07:56 AM
Neldawg
Jul 16, 2006 11:00 AM
mrchaikel
May 28, 2006 06:15 PM
