need actual electronic vss wiring info
If someone has a proper link or not a broken on please pm me. this is the last thing i need to do to my rex. or a quick write up. where do these 3 wires go.
i will edit this post and make it diy with pictures if someone gives me some good info!
Not exactly sure on what it is your are asking...
B10 is where the VSS is on ECU connector. The three wires going left to right looking on the locking tab on the sensor/ plug itself should be = ground (black) - power (yellow) - output (orange). Power should be 5 volts? Not 100% sure on power though - this is all from memory though...
