02 Blazer f/t
Old Jun 19, 2011 | 08:52 AM
thinkskater's Avatar
Default 02 Blazer f/t
To start I purchased this blazer from a relative that had ran the truck low on coolant because the intake manifold gaskets leaked coolant. This resulted in blowing one of the head gaskets.
I bought the truck last spring and had begun disassembly by the beginning of summer. The truck had quite a few oil leaks as well so I decided to do a lot of preventive work along with the obvious.
I have a notebook full of receipts for all the parts bought.
2002 Chevrolet Blazer
155k miles- does not get driven much miles will be very close to this.
vin available upon request
Options
- Working 4 wheel drive ( makes snow FUN )
- Sunroof works great
- Auto trans flushed at 150k
- Heated mirrors
- Rear disc brakes ( new pads and rotors at 148000 )
- Power windows
- Power door locks
- Power mirrors
- Rear wiper
- Air conditioning ice cold
Receipts for the following
- New cylinder heads
- New upper and lower gasket set(heavy duty head gasket and intake gaskets)
-head gaskets, intake gaskets , valve cover gaskets , oil pan gaskets, rear main seal
- New timing cover
- New water pump
- Full tune up
-Plugs,wires, cap, button, fuel filter, fuel line o rings.
- Front end work ( front end is tight )
-Upper and lower ball joints, idler arm
- Rear rotors and pads
- Transmission flush
- Transmission seal replaced while the block was out
- Every single hose was replaced
- upper lower both heater and water pump rubber lines
- One 02 sensor
After market stuff
Tires and wheels
-Black rock 15x7 -13 offset less then 500 miles
-Big X/T tires - 30x9.5x15 brand new less then 2000 miles 14 32nds of tread left on all four no cupping at all
-Ebay cold air intake system- less then 500 miles on it
System
-Sony head unit-bluetooth built in aux on faceplate
-Sony door speakers just bought last month
-Wired for amp and sub
Issues
-Windshield cracked - not in the line of vision will pass inspection
-Passenger window does not roll down most of the time
-Leaks oil from the oil cooler lines ( VERY SLIGHT LEAK, Doesnt even register on the stick at the oil change intervals)
-Check engine light for a Random misfire
- This CEL is VERY common for the 4.3 and is very difficult to diagnose. The truck has a tiny bit of a rough
idle , barely noticeable. The truck will pin your head in the seat in 10 inches of snow. Performance is
not effected by the CEL.
-Tires Scrub
Open to all trades. I love this truck, but honestly do not need it since i now live in town.
Would trade for anything really. No junk though.
Will sell for 5200 OBO
Truck is located in midmo.
pm for best response.
civicguy167
Dec 12, 2012 09:11 PM
akamrmike
May 1, 2009 09:39 AM
BigBadBuford
Jan 6, 2005 03:07 PM
