Smallest radiator with turbo setup - Thermostat?
Old Jun 19, 2011 | 07:54 AM
crxhybrid1320's Avatar
Default Smallest radiator with turbo setup - Thermostat?
Last time I had my crx on the road it was overheating without boost. Was told to drill small holes in the thermostat to slighly increase coolant flow.
Currently running the largest fan that will fit on the radiator.
Full-race radiator T4 turbo.
Pics or suggestions.
Old Jun 19, 2011 | 09:42 AM
DRAGLS's Avatar
Default Re: Smallest radiator with turbo setup - Thermostat?
I put a electric water pump and a gutted thermostat and a 24lb radiator cap.
Old Jun 19, 2011 | 10:02 AM
Size of radiator?
Setup?
Old Jun 19, 2011 | 10:07 AM
DRAGLS's Avatar
13"x17" radiator, 12" spal fan.
top mount, 67mm, LS engine.
Old Jun 19, 2011 | 01:27 PM
Mine 10x14" with 10" fan
holes drilled in thermostat
oem waterpump
Old Jun 19, 2011 | 01:41 PM
DRAGLS's Avatar
So you have about a gallon or less of coolant trying to keep a street car cool?
Old Jun 19, 2011 | 02:26 PM
Redline130's Avatar
How much airflow are you getting to the radiator? Is your intercooler blocking a lot of it?
Old Jun 19, 2011 | 04:31 PM
turboda4dr's Avatar
sorry for the thread jack. my intercooler is blocking most of the radiator, is there a way to change that?
Old Jun 19, 2011 | 06:15 PM
It sucks it was overheating with the front bumper off also.
Im going to sell the kit i think.
Old Jun 19, 2011 | 07:10 PM
Redline130's Avatar
For the most part no. Unless you go with a smaller/shorter intercooler or you can figure out a way to route fresh air to the radiator. Heat wrap, coolant additives, and shimming the hood might help with under hood temps, but unless the radiator sees cooler air, it's not going to be able to keep temps low.
Old Jun 20, 2011 | 05:50 AM
Any other guys have info on there radiator/thermostat setups
Old Jun 22, 2011 | 03:43 AM
Thompson32479's Avatar
My car will over heat also, only after driving about 20 mins with very little boost randomly used? ( just did headgasket, arp studs due to bad head gasket ), i was thinking of trying a 170 degree themostat. Should i opt for that and possibly a better cap? btw my intercooler is blocking also hmmmmm 1 thing i cant stand is a overheating car
Old Jun 22, 2011 | 04:16 PM
Ive been told to drill a few holes in the oem stat. So i did that
Old Jun 22, 2011 | 06:02 PM
shocker911's Avatar
drill out the T-stat then i would wire up a fan switch to run the fan all the time....run wetter water and change your coolant.
is your fan pushing or pulling?
Old Jun 22, 2011 | 07:06 PM
th3pwn3r's Avatar
Pics?
Old Jun 22, 2011 | 07:59 PM
EsotericImage's Avatar
Retired Moderator
i had cooling issues in the hot florida sun..
I went with the bullshit 12" Mishimoto fans, fan shrouds, etc..
I finally broke down and slapped down 80 bucks for this
http://www.xenocron.com/maradyne-13-...a2b52c08ef77e0
Mount this up and your cooling issues will be gone!
Old Jun 24, 2011 | 04:19 PM
cant mount a 13" fan on a 10' radiator
Old Jun 25, 2011 | 08:04 AM
Hyper16-Johnny's Avatar
I haven't had any problems with my Mishimoto setup. I have the half-sized radiator, fan, shroud, and cap with the temp gauge. We even hot lapped it on the dyno when it was getting tuned with no issues. Then again, I have no thermostat.
I don't have pics but I have this vid where you can kind of see it.
http://www.youtube.com/watch?v=OjSL4Onf4fQ
Old Jun 25, 2011 | 12:36 PM
pcguy760's Avatar
Anyone using an oem setup with a slim fan? I have been using an oem Honda dual core, half size radiator with oem cap, oem hoses, oem thermostat, oem waterpump and a Spal slim fan on a turbo H22A - even on hot days with hard driving and stop go traffic, heat gauge never touches the halfway mark... make sure you have bled the cooling system correctly as well...
Old Jun 25, 2011 | 01:06 PM
DRAGLS's Avatar
True, since honda temp gauges are so accurate.
Old Jun 26, 2011 | 08:39 AM
any other input or pics
Old Jun 26, 2011 | 01:03 PM
DRAGLS's Avatar
What's overheating to you? What is your water temp getting up to?
With a 10"x14" radiator and 10" fan there isn't much you can do.
Get a E-water pump and a 24lb cap with a gutted thermostat and hope that works.
Old Jun 26, 2011 | 06:09 PM
90civichbsi's Avatar
You need a better fan and fan shroud. I am running a generic alumnium 92-95 civic radiator with a 12" spal and a custom shroud, stock t-stat, water pump, fan switch and radiator cap. I was doing 20-30 minute sessions on a road course in 95-100 degree texas heat. My temps didn't go past 220.
Shorty manifold, 50 trim t3/t4, 305hp, intercooler covering all of the front air dam and stock hood.
Old Jun 26, 2011 | 06:23 PM
96electronH's Avatar
I was on k-teller earlier they have a 13" slim fan flowing 1550cfm for 30 bucks. Just putting it out there.
Old Jun 28, 2011 | 04:06 PM
Anyone running the PWR 10" radiator??
