2000 civic lx 4dr turbo quality parts!
Im helping a buddy sell his car, he has moved to another state and has no use for this car anymore. Please only serious buyers no dreamers, if you don't have the funds to buy this please don't waste your time or mine. Please read post carefully, no trades! no low ballers!, no joy rides. The car is ready to be sold first come first serve, no holds, no waiting on loans or rich uncles, ants, or lottery tickets to be cashed. You guys get the point.
Now for the info. Please read carefully as I will not answer questioNns that can be answered on this post.
2000 civic lx four door black color with grey interior 75k miles
Freshly dyno tuned by Mikey at pro function
made 358whp 237torque at 10psi very conservative street tune.
Engine:
Gsr motor built by Mikey at pro function 6k miles ago
Eagle pistons and rods 10:1 compression
New oil oem oil pump
New all oem bearings
New all oem seals, and I mean all of them.
B16 head
Supertech flat face valves
Blox spring and retainers
cometic head gasket
arp headtuds
usdm itr cams
new valve seals
moroso oil pan
oil filter relocator
custom oil cooler
edelbrock intake manifold
pro fab intake manifold gasket
new water pump
new timing belt
endyne catch can
aem fuel rail
b&m fuel pressure regulator
750cc rc injectors
aeromotive fuel filter
ngk spark plugs
ngk spark plug wires
fluidyne radiator with slim fan
Turbo setup:
Peekbost turbo kit
t3/04 garrett turbo
3" peekbost downpipe
tial wategate
tial blow off valve
peekboost intercooler
peekbost turbo piping
all coupler are double ply with t bolt clamps
peekboost ramhorm tigwelded turbo manifold jetcoated black
skunk 2 2.75 exhaust all the way back
Transmission:
gsr trans with itr lsd(LSD was purchased new)
no grinds
Skunk 2 dual bend shifter
ebay shift ****
gator axles
innovative mounts
Exedy 3 puck stage 2 clutch
Act flywheel
Exterior:
Civic si side skirts
Civic si front grille
Rear lip trunk spoiler
Electronics
Hondata s300 with dual boost optional(is in the ecu, but has not been set)
hondata 4 bar map sensor
plx wideband
autometer boost gauge
automoter oil pressure gauge
civic si cluster
apex turbo timer
gizmo electronic boost controller
Suspension:
Apex pic coilovers 8k front 10k rear
Pic real lower control arms
blox rear camber kit
Skunk 2 new style front camber kit
All front bushings are poly
Tie rods, balljoints were all replaced 6k ago
Car was recently aligned as well
dc sports rear lower tie bar
New steering rack(converted to manual rack)
Interior:
Pretty much stock other than a del sol seat drivers side
Power windows
power locks
power mirrors
ctr shift boot
pioneer radio
pioneer speakers all around
Brakes:
Gsr front brakes
Ebc front pads
cross drilled and slotted rotors
civic si master cylinder
rear oem drums
Wheels:
tenzo r 17x7 neo gen 205/40/17 tires
The car doesnt have any rust anywhere on the body, all original panels with vin numbers all around. Never been driven in the winter, never been in an accident. The car was built and then when it was finally done my buddy moved away and left it behind. The car has been sitting in a garage for a while now. Mechanically the car will be all in perfect working condition all fluids will be changed and a full detail will be done.
Car is located in Chicago.
Price:6300.00
Engine:
B16 head
cometic head gasket
arp headtuds
usdm itr cams
new valve seals
moroso oil pan
custom oil cooler
new water pump
new timing belt
endyne catch can
aem fuel rail
750cc rc injectors
ngk spark plugs
Turbo setup:
Peekbost turbo kit
t3/04 garrett turbo
tial wategate
tial blow off valve
Transmission:
no grinds
ebay shift ****
gator axles
innovative mounts
Act flywheel
Exterior:
Electronics
plx wideband
civic si cluster
apex turbo timer
Suspension:
Interior:
Power windows
power locks
power mirrors
ctr shift boot
pioneer radio
Brakes:
Gsr front brakes
Ebc front pads
rear oem drums
Wheels:
Price:6300.00
