rear lower control arm question
Old Jun 18, 2011 | 07:48 PM
gsr_b20b's Avatar
Default rear lower control arm question
hey guys im working on my gfs 91 hatch and i came across a problem. Its the typical strut bolt breaking in the rear lower control arm problem. So i pulled the lower control arm off the car (after cutting the stock strut off the control arm) and ive tried heating and putting wd-40 on the broken bolt and tried hammering the **** out of it to try knock it out but no luck. So my question is, are eg (92-95) rear lower control arms the same as ef ones? thanks for any help guys, im stuck!
Old Jun 18, 2011 | 08:00 PM
Tyson's Avatar
Default Re: rear lower control arm question
not the same, but itll work identically, unless you have an Si. EG doesnt have swaybar mounting holes.
you should cut the bolt off and replace the bushing on the original control arm tho.
daniel-em1
Suspension & Brakes
Jun 13, 2011 02:41 AM
MaXiMuS1701
Jun 29, 2007 10:12 PM
BG-Teg
Jun 3, 2007 06:54 PM
Hyb
Feb 2, 2005 05:55 PM
