Spark plug hole full of oil!! Help
Old Jun 18, 2011 | 05:48 PM
SeanaK's Avatar
Default Spark plug hole full of oil!! Help
So I recently changes the valve cover gasket and the o-rings. I even took the rocker off to get to those hard to get ones. I was putting on new spark plug wires when i noticed the second plug hole was full of oil!! what could be the problem?? all the other spark plug holes are clean and there was no oil. help
1990 honda accord ex
Old Jun 18, 2011 | 05:52 PM
00siboy's Avatar
Default Re: Spark plug hole full of oil!! Help
did a gasket get pinched or slip out of place, pics always help too.
Old Jun 18, 2011 | 05:56 PM
SeanaK's Avatar
Well i just took off the valve cover and those gaskets seem to be fine
it might be the lower ones but it would suck if i took the whole assembly off and it wasnt (I replaced them like 2 or 3 weeks ago)
Old Jun 18, 2011 | 06:03 PM
00siboy's Avatar
i don't know man its hard to tell without seeing...
Old Jun 18, 2011 | 07:47 PM
GhostAccord's Avatar
Clean it up and run the car for a little while, until you see a little bit of oil again. That way you will be able to see if the oil is running down the side of the spark plug tube from the upper seal or if it is coming in from the lower seal.
Old Jun 20, 2011 | 06:17 AM
00siboy's Avatar
do this^
Old Jun 20, 2011 | 10:21 AM
SeanaK's Avatar
Kay so I just took another look at it, ran the car and watched for oil. it looks like its coming from the upper seal. I took the valve cover off and the seals not pinched or anything. both the upper seal and the lower seal are brand new.. what could be the cause?
Old Jun 20, 2011 | 10:26 AM
SeanaK's Avatar
Old Jun 20, 2011 | 01:15 PM
SR20S13's Avatar
its prob. the gasket under the rocker arms
Old Jun 20, 2011 | 01:29 PM
Check the gasket, maybe there is a small blemish on one side of it where it is not allowing for a flat seal. When you remove hte valve cover and look at the seal you should be able to see if the sealing surfaces are wet with oil. if they are then they are not sealing and maybe that seal is crushed or out of spec.
Try replacing it or you could try running a bead of Honda-bond on both the top and bottom of the gasket.
Old Jun 22, 2011 | 09:18 AM
00siboy's Avatar
^this. hondas have hi-pressure oil systems and throw oil everywhere, so any tiny imperfection could be leaking
SeanaK
Jun 24, 2014 03:22 PM
erik_mullen
Mar 13, 2011 07:07 PM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
janz3n
18
Apr 20, 2006 06:34 AM
mailforjon
Aug 5, 2002 04:34 PM
