Help with bad gsr engine
I just bought a 97' gsr all stock. engine was knockig nd ended up just stoping after a five inute drive. would it be worth fixin aka rebuilding the enjine or better off just trying to buy a gsr engine. if rebuilding is an option what do i need to do??? thankx
as said above find out why it was knocking and go from there.
personally if it was my car and money was not an option id send the block/head into a good machine shop and start ordering parts and just build it from ground up then get a good tune and call it a day..
good luck brotha
good luck brotha
Figure out where the knock is coming from. If its a bearing just sell the motor as is and advertise that it has a rod knock. Someone will pick it up for $600. Go buy a Jdm Itr long block for about $2400 from a reputible importer, bolt your trans up to it, and your good to go. Trust me, you will spend a lot more time and money to rebuild it correctly than a good Itr motor will cost you.
it's likely not a knock, but rather piston slap. after the engine heats up, the clearance between the skirt and cylinder walls gets tighter through expansion.
you can either just live with it, or pull the engine and have the cylinders checked for taper/out of round, re-bored and honed. taper of the pistons checked as well and compared with the readings from the cylinders to calculate clearance.
or you can just try and find another b18c bottom end in good shape
rebuilding or making some attempt to fix it will at least help you know more about the motor. Selling it and buying another one will land you back in the land of the unknown.
OP - step 1 is to see what's wrong and decide what you're willing to invest in that engine vs the cost of an engine you could get from another source. What you decide to do depends on your long-term goals as well as the funds available to you.
the itr while faster will require more cash to convert since you'll need a p73-a02 ecu and the proper evap solenoid
the gsr will require the oil pump swap and vtec solenoid but will run on your oem ecu
all said and done the gsr will run around $1000 less to make pass
but
the R is faster
mpg is nearly identical
shivic
Oct 16, 2003 06:46 PM
