91 accord coupe turn signals will not work.
Hey guys my honda accord is suffering from these symptoms. My turn signals dont work but my emergency flashers work.
Ive replaced the following
Flasher
Mult function switch on the steering column
All fuses
All bulbs
Am I overlooking something.
Flasher
All fuses
All bulbs
Have you been able to verify the bulbs flash when you turn the signals? Also, do the indicators on the dash work? There may be a open circuit or bad ground. Consult with a multimeter.
The bulbs do not flash when I use the turn signal switch nor does the dash register any activity, but when the emergencys are on all the bulbs flash and the dash flashes like its supposed to
NJaccord2000
Sep 15, 2013 11:53 PM
