LS/VTEC Timing Adjustment Issue
Old Jun 18, 2011 | 03:47 AM
alperx's Avatar
Default LS/VTEC Timing Adjustment Issue
While I try to adjust the distributor position with the timing gun,
Should the sign on the timing cover plastic align with the middle BTDC sign for 16 degrees just like the typical Integra LS ?
I have a B18A1 block with GSR head & GSR Distributor.
Old Jun 18, 2011 | 05:08 AM
alperx's Avatar
Default Re: LS/VTEC Timing Adjustment Issue
If I do it, at idle, the motor doesnt sound normal.
While running, it makes small blasts from the muffler. Just like I advanced it too much.
(I use neptune rtp and lock the ignition at 16 degrees.)
what can be wrong ?
Old Jun 18, 2011 | 05:54 AM
dk=gsr's Avatar
yea it should be at 16 btdc
Old Jun 18, 2011 | 08:48 AM
alperx's Avatar
what can be wrong ?
Old Jun 18, 2011 | 11:13 AM
94dxcoupe's Avatar
With your timing light set to 0 degrees, and the ignition locked at 16 degrees, the pointer on the cover should line up with the WHITE mark on the pulley...
Old Jun 18, 2011 | 11:51 AM
alperx's Avatar
well, ok, but, isn't it same with my timing light set at 16 degrees and cover pointer line up with the RED mark on the pulley ?
here's the thing. I just came from some playing with it. After setting the BTDC to 16 degrees, when car is about 180 degrees, no problem.
When the car reaches 195 degrees F, it starts to make uncontrolled small blasts from the muffler.
is this pre-ignition ?
Old Jun 18, 2011 | 08:21 PM
slowcivic2k's Avatar
blasts from the exhaust is after-burn, a characteristic of retarded ignition timing.
Pre-igntion would manifest itself in the intake manifold or combustion chamber before TDC, and can in some instances cause severe damage to the manifold or the rotating assembly.
Old Jun 18, 2011 | 10:51 PM
alperx's Avatar
ok so if it's because of retarded timing, why does it happen when I advance the distributor to find the 16 degrees BTDC ?
The car sound turns to normal when I retard the distributor.
Old Jun 19, 2011 | 01:22 AM
mouab18c1's Avatar
What? Really?
Old Jun 19, 2011 | 08:59 PM
alperx's Avatar
if u set the timing gun to 0 degrees and point to WHITE (0 degrees), then it's the same thing as a basic timing gun pointing at 16 degrees BTDC.
can "blasts from the exhaust" mean any vacuum leak ? because I think I have some.
When the engine is cold, the idle go up and down until the car gets warmed up.
Old Jun 19, 2011 | 09:58 PM
mouab18c1's Avatar
So what you're saying even with the ecu jumper harness jumped. If you have your timing in Neptune at 16* then with a timing gun it will point to the White mark at 0 degrees?
Old Jun 19, 2011 | 11:13 PM
alperx's Avatar
the "0 degrees" theory seemed correct if you retard the timing gun to 0 degress with the **** on it.
but that is not what I did.
what I did is : 16 degrees in neptune, 16 degrees at the timing gun, middle red marker linep up with the mark on the timing belt cover.
Old Jun 19, 2011 | 11:42 PM
mouab18c1's Avatar
Then you're fine. When I change my timing gun to 16* The red mark "16*BTDC" will walk away further from the timing belt cover.
Old Jun 19, 2011 | 11:58 PM
alperx's Avatar
OK, but after I do this, the motor works like it's leaned out - but the AFR show me it's around 14:1
The motor doesnt work quite well. what should I check else ?
I changed the sparks.
Old Jun 20, 2011 | 12:16 AM
mouab18c1's Avatar
If you're timing is dead on then timing is not your issue. BTW what is included in your setup? Cams, etc.
I forgot if you mentioned it, but is it tuned?
Old Jun 20, 2011 | 12:28 AM
alperx's Avatar
The cylinder head is completely stock (b18c1 Integra GSR)
the basecode of Integra GSR is loaded. I adjusted the AFR, it's around 14:1
Old Jun 20, 2011 | 01:41 AM
alperx's Avatar
also, the distributor is brand new, but not OEM.
Old Jun 20, 2011 | 02:02 AM
mouab18c1's Avatar
If you're just on a basemap, then it needs to actually be tuned. What do you mean as in the motor does not work well?
Old Jun 20, 2011 | 10:13 AM
alperx's Avatar
it is tuned by me according to 750cc injectors.
I'm talking about the idle ignition problem, nothing else yet..
Old Jun 20, 2011 | 10:47 AM
kyden's Avatar
that is incorrect. if you put 16 degrees on the gun, you should be at the white mark on the pulley, which is 0 degrees. 0 degrees on the gun should be at the red mark.
Old Jun 20, 2011 | 02:07 PM
alperx's Avatar
if it's %100 percent true, than my problem is solved..
Old Sep 10, 2011 | 10:06 AM
SciKtC's Avatar
Im having a similar problem with my ls/vtec I'm a nood to hondas and Im having trouble setting the timing it a b18a1 block with a b16 head.it also has skunk 2 cam gears. damn car has been driving me nuts for a week...
Old Sep 10, 2011 | 04:48 PM
civickiller's Avatar
set physical timing to tdc, then timing light with distributor how kyden said
anoble1
Apr 5, 2019 04:33 PM
98bucket
Nov 21, 2010 03:57 PM
EKB18BPR3
Nov 30, 2003 10:36 AM
rioninja
Aug 4, 2001 05:48 AM
