Fs: crx si interior parts, stanley side markers, engine harness, p28
Old Jun 17, 2011 | 09:29 PM
Emoney97ss's Avatar
Default Fs: crx si interior parts, stanley side markers, engine harness, p28
Stanley Side Markers-30
CRX SI engine harness(not one cut wire)-100
CRX SI engine harness(the distributor plug has two cut wires easy fix)- 70
Black Projector Headlights with mounting brackets-35
Stock headlights without brackets-50
P28 Ecu-100
ObdO two Obd1 jumper harness-50
Trunk side panels(Speaker grill, and both triangle pieces included)-45 each
Entire sunroof with working motor (no glass)-60
Sunroof Open close switch-25
Rear Trunk cover-10
Center vents with working clock- 30
Rear view mirror with seatbelt light- 25
Entire carpet no rips blue in color- 60
Gauge cluster with 241,xxx miles- 30
Dome light with cover- 15
Driver and Passenger A pillar covers-20 each
Rubber that goes around the top of each door-10 each
Sun visors- 25 for both
Rear Corner plate that normally says si or hf (this one has sticker pulled off)-25
Fuse cover under dash-20
No name intake with filter-45
No name electric fan- 40
Black window crank- 10
Emergency handle trim- 10
Entire Shifter trim- 35
Radio trim with change compartment- 35
All parts are obo, but prices are pretty reasonable already. I may go lower if you buy more then one thing. If you have any questions please text me at 760-267-3287. All parts are located in cypress, very close to the college.
Old Jun 18, 2011 | 03:26 PM
Emoney97ss's Avatar
Default Re: Fs: crx si interior parts, stanley side markers, engine harness, p28
Prices are obo
Emoney97ss
Jul 3, 2011 11:07 PM
switchd9497
Nov 29, 2004 06:56 PM
