b20vtec oil light flashing
Old Jun 17, 2011 | 04:39 PM
negusjuda's Avatar
Default b20vtec oil light flashing
so i was driving my car today and when i came to a stop light my car started to idle funny then shut off at the same time as i stopped my oil light was flashing i checked oil wasn't low checked oil sending unit it was plugged in so i started it up and it was doing a idle surge and oil light was still flashing so then i pulled over into a gas station and looked over the car some more for anything leaking but found nothing so i let the car sit for a while and started back up and idle surging was gone and oil light was off but i cant seem to figure out why it idle surged and why my oil light started flashing im getting a oil pressure gauge tonight to see if maybe my oil pump is starting to give out
Old Jun 17, 2011 | 04:41 PM
negusjuda's Avatar
Default Re: b20vtec oil light flashing
ps sorry for the punctuation. also i got the car street tuned yesterday and with about 10 or 11 wot pulls it showed no signs of stalling and no oil lights until today
Old Jun 17, 2011 | 07:14 PM
C_Rock77's Avatar
Get a manual oil pressure gauge and check your oil pressure.
If your oil light came on due to low oil pressure...the sensor was seeing less than like 5-7 lbs of oil pressure.
Old Jun 17, 2011 | 08:51 PM
negusjuda's Avatar
yea im hoping to get one this week end
Old Jun 17, 2011 | 11:43 PM
C_Rock77's Avatar
Well, don't be a brain-dead idiot and drive the car....unless you WANT to rebuilt your engine.
Old Jun 18, 2011 | 03:46 AM
negusjuda's Avatar
No it's staying parked
Old Jun 18, 2011 | 04:01 PM
negusjuda's Avatar
would it be better to hook up the oil pressure gauge on my sandwich plate or replace the oil sending unit with the gauge
Old Jun 21, 2011 | 12:57 PM
negusjuda's Avatar
so i finally got a oil pressure gauge put on my car at idle im at 20 psi and at 3k til about 8300 im at 80 psi so i would assume oil pump is good what i did notice is that from first start up til about 160 miles on the engine i was running valvoline 5w30 i did a oil change yesterday and switch to castrol 10w30 and it made a significant diffrence car seems to run a lot stronger and it dosent seem to stumble and dip low in rpms anymore also i think my oil sending unit was leaking
rak511
Engine Management and Tuning
Feb 14, 2014 05:36 PM
raverx3m
Dec 6, 2010 06:06 PM
95_red_dc
Apr 2, 2008 06:17 PM
GraphiteMW
Sep 2, 2007 11:07 AM
wwcivic
Sep 8, 2001 11:45 AM
