help with wiring
This is an EXTREMELY vague description you gave sooo... What pin outs are you talking? Did you know the ECU controls the GROUND side of the injectors? Are you testing with a noid light? Did you check to see if you have voltage at the injectors?
no voltage to injectors i thought it was a ground but i wasnt forsure its a dx harness on h22a if we put gas in intake it runs but then shuts off cuz injectors arent working
