Cheapish - 10.5:1 Arias 84mm Arias Slugs and Eagle LS/D16 900hp Rods
Please bump if viewed
Well guys need some money so I'm parking out my built block, at least the internals because I've decided when I have the money to finish the project I'll be switching pistons and rods anyways. So on to pics and prices.
These internals have about 1500 miles on them. Numerous dyno pulls at T1 Race Development in Texas, tuned by Tony Palo. The engine made 605 hp on 24 PSI C16 fuel on a measly 6262 Precision which is small for this engine and setup. Made 425 on pump gas on just 14 psi. So you know it was tuned right and you know the power levels, etc.
Pistons: $300 shipped
Manufacturer: Arias
Part Number: 3310000
Bore: 84mm
Dome Type: Flat Top
Compression [LS 45cc | B16 42.7cc | GSR 41.6cc]: 10.4:1 | 10.6:1 | 10.9:1
Weight [Gram]: 295
Link New: Arias Manf. $600 | Golden Eagle MFG. $500
Pics:
Connecting Rods: $225 shipped
Manufacturer: Eagle
Part Number: CRS-5934-B
Length: Standard 5.394" | 137.01mm
Beam Type: H Hybrid
Engine Compatibility: B20, B18A/B, B18C1 w/ B18A/B Crankshaft, All D16 with piston pin bushings
Weight [Gram]: 295
Link New: Eagle Specialty Prod. $400 | [http://www.maperformance.com/eagle-f...]MAPerformance $346[/url]
Pics:
There are no cracked ring lands or irregular wear on pistons. Rods are not bent, nor are there any spun bearings or signs of heat fatigue. More specific pictures can and will be taken for anyone who is serious about a purchase. Rods will come with the bearings in for personal inspection of spun bearings, as well as if you're on a budget I promise the bearings are usable as long as they measure within spec on your crank. I will do $475 Shipped for both as a set, that is a $50 savings.
Manufacturer: Arias
Bore: 84mm
Dome Type: Flat Top
Weight [Gram]: 295
Pics:
Manufacturer: Eagle
Beam Type: H Hybrid
Weight [Gram]: 295
Pics:
lawjdl16
Apr 1, 2013 12:16 PM
