56K(maybe)-B18C,B16A2,TURBO KIT,RIMS,VISORS,JDM,ITR,DC2,AND MUCH MORE,CHEAP PRICES!
So my ctr is finally finished and now i need to get rid of all the extra parts im not using for it.All parts are located in oak hills 92344 i might be able to meet..if you need better pics just send me a text..keep negative comments to yourself..prices dont include shipping..most prices are OBO!
WILLING TO TRADE ANYTHING IN THREAD FOR..
b series turbo exhaust manifold
5 bolt downpipe
ek b series ic piping
b series engine parts
5 lug rims
jdm ek hatch parts
or show me what you have..NO LOWBALLERS..serious offers will be takin into consideration...
TEXT ONLY 7607131947
EMAIL: DC4LSTEG@gmail.com
PLEASE BUMP IF VIEWED
NOW ON TO THE PARTS!
15" oem itr rims w/ 95% falken 512s..some stains on the rims..FOR TRADE ONLY..
FT ONLY for another steering wheel show me what you have mine is still like new..
B Series Turbo Kit..Dont know what kind of car the piping will fit, comes with everything shown..$325..
01 GSR B18C1 block..has jdm b16 pistons pulled from my running integra, was smoking some so it may need new rings..$600
OEM 94-01 integra window visors...$130
turbonetics turbo..exhaust .60..never used since rebuild..5 bolt will also come with 5 bolt flange for downpipe...$500
ek stock b series mounts...$50
jdm gsr block..complete short block..everything has less the 200 miles on it..the rings didnt seet right so it only needs new rings..has ctr pistons..$450
Jdm Itr header..part where donut stays on is cut, showed in pic, easy fix..$200
B16 cams..$30
1 HID ballast with bulb...$40...
92-00 civic Oem antenna block off kit complete never opened..$25
00 ls integra ps rack and subframe..$50
set of 4 hubcaps..$30
unorthodox camgears..$75
pass side integra fender..$20
black dc dash $50
integra gray front and rear seatbelts..$30 for front $20 for rear..$40 for all
integra oem sunroof..uncracked and works...$80
gray integra headliner..in pretty good condition..$20
black piece that goes under dash..$10
black integra glove box..$10
integra black trunk piece..$10
00 ls front and rear sway bars..$30 each $50 both
integra gray c-pillars..$30
integra gray a-pillars..$20
integra black cluster bezel..$10
integra antenna..$10
94-01 integra drvside knuckle..$20
ek front and rear brakes..$50
eg stock rear suspension..$20
eg rear drum brakes..$10
98 ek9 ctr ac fan comes with everything shown..$40
obd2 p72 ecu..$75
obd2 p73 ecu..$90
obd2 p75 ls/b20 ecu..$50
ls cluster..i have 2..$40 each
dc front strut bar..$20
set of 5 donuts..$20
5X??? blackies..told they were 5x114 they arent..$10
Fender guitar..comes with case and amp everything is still like new..$150
forum snowboard w/ burton freestyle bindings..scratched up some on bottom...$40
5 bolt downpipe
5 lug rims
jdm ek hatch parts
B16 cams..$30
black dc dash $50
obd2 p72 ecu..$75
obd2 p73 ecu..$90
like the b18 c1....is it legit,,,no compression problems? and comes with crank rods pistons...? wher u located?
in the process of looking for a good gsr block to get new sleeves and built....
thanks for ur time
j
thanks for ur time
j
