D16z6 Swaped Crx!
Old Jun 17, 2011 | 08:32 AM
tpnorth's Avatar
Default D16z6 Swaped Crx!
Okay got it my crx running and idling but now after it gets over 3500rpm and it just starts bogging and shitting out then youll let off it will be fine then again at 3500rpm.Now im running a stock p28.Ive tried replacings the iacv the tps new plugs double checked wires. The car is a little out of timing but nothing crazy thinking i may just need a base map for the ecu.But looking for some insight!
Old Jun 17, 2011 | 09:00 AM
racejunke13's Avatar
Default Re: D16z6 Swaped Crx!
Every time I have ran into problems like yours it has been a timing issue. Although a good tune wont hurt
Good luck
Old Jun 17, 2011 | 09:07 AM
tpnorth's Avatar
i threw a timing light and it was out a little but i tried to adjust the dizzy as much as possible so im hoping having a base map with correct the electrical timing enought to fix the stumbles.Also reading around from what i understand you can put the ecu in some sort of safe mode? How can i reset that?
Old Jun 17, 2011 | 06:09 PM
rpmraper's Avatar
you fix that ( limp mode) by fixing the problem with the car. re map your base map, ive been there too and it worked..
SupraSean91
Jan 22, 2015 06:22 PM
VTC_CiViC
Engine Management and Tuning
Jul 28, 2014 12:16 PM
slowsleeper
Jun 8, 2011 07:00 AM
champwhiteEG6
Jul 10, 2009 07:52 AM
Racergurlie
Jul 29, 2003 02:49 PM
