Suspension & Brakes Theory, alignment, spring rates....
More stiffer rear springs?
Old Jun 17, 2011 | 07:21 AM
23LX23's Avatar
Default More stiffer rear springs?
I drive a 2000 civic ex and I put Tokico shocks/springs about 1.5 years ago... Now the set up is really low where to the rear fender is right above the tire... I occasionally have people in the back and then the fender is going over the tire, something I dont want because I also want to add a subwoofer and then itll just be more weight... Are there other springs I should look into that arent as soft? Or is there another alternative I can look into?
Old Jun 17, 2011 | 07:30 AM
kaiba's Avatar
Default Re: More stiffer rear springs?
I'm guessing you have lowering spring? Look into coilover.
Old Jun 17, 2011 | 08:48 AM
sowellman88011's Avatar
if ur gonna buy more springs u might as well get an adjustable set of coilover sleeves. if u problem is rubbing u could roll the fender lips.
Old Jun 17, 2011 | 01:43 PM
GagnarTheUnruly's Avatar
You could get ground controls in pretty much any spring rate you want and getting stiffer springs might help. You still only need four of them though.
Old Jun 17, 2011 | 06:28 PM
23LX23's Avatar
Yes I do have lowering springs... Would it be smart to put to put coil over sleeves on these shocks or is that dumb?
Old Jun 17, 2011 | 06:49 PM
mechanix619's Avatar
You'd be fine. Just get an appropriate spring rate.
Old Jun 18, 2011 | 11:52 AM
pwebb0207's Avatar
more stiffer?
Grwa209
Suspension & Brakes
Jan 9, 2013 09:33 PM
sohcpoweredeg
33
Sep 22, 2011 05:36 AM
Rease3
Mar 21, 2010 04:23 PM
moores55
12
Apr 24, 2006 09:25 PM
owen_the_soyboy
Jun 29, 2001 12:43 PM
