skunk stage 1 cams vs. ITR or CTR cams (yes i did a search)
Old Oct 1, 2002 | 09:53 AM
311's Avatar
311
Default skunk stage 1 cams vs. ITR or CTR cams (yes i did a search)
someone give me some input on the benifits of each in a jdm 1st gen b16. thanks.
Old Oct 1, 2002 | 10:07 AM
ImportechPerformance's Avatar
Default Re: skunk stage 1 cams vs. ITR or CTR cams (311)
obviously the skunks stage1 cams will outperform any of the R cams....
'00+ ITR AND CTR cams are the same you can pick em up for like 300 bucks for both
Skunks for like 600+
Skunks1 are still really good for street and better for strip than R cams but its up to how much money your willing to spend.....
If i had the money def...Skunks1
Do a search theres a gazillion amounts of info on this!!!
Old Oct 1, 2002 | 10:22 AM
311's Avatar
311
Default Re: skunk stage 1 cams vs. ITR or CTR cams (TheRedSkoolingBus)
thanks alot, anyone else with some dyno numbers?
Old Oct 1, 2002 | 10:48 AM
TimoneX's Avatar
New User
The skunk2 stage 1s are similar to the CTR in lift(slightly higher), they're moderately longer duration. Although they'll almost certainly outperform the CTR cams, they're also more costly. My reasoning is if you're going to swap out the cams, then make it worthwhile. The stage 2 & stage 3 cams are somewhat more, and you need stronger springs & retainers, but I think it a more worthwhile venture.
Old Oct 1, 2002 | 02:15 PM
vtecmissle's Avatar
Default Re: skunk stage 1 cams vs. ITR or CTR cams (TimoneX)
i would like to know where i can get cheap r cams.
Old Oct 1, 2002 | 02:23 PM
TimoneX's Avatar
New User
Default Re: skunk stage 1 cams vs. ITR or CTR cams (vtecmissle)
I'd watch eBay. Allot of people buy CTR intake and ITR/CTR exhaust cams, install them a very short while, then decide they want more power than they'll get from them.
Old Oct 1, 2002 | 03:27 PM
piatl7il77's Avatar
save up and gt the skunk2's
Old Oct 1, 2002 | 03:50 PM
B00ST2nR's Avatar
Default Re: skunk stage 1 cams vs. ITR or CTR cams (piatl7il77)
Skunk2's!
Old Oct 1, 2002 | 04:23 PM
GSRdriver's Avatar
Default Re: skunk stage 1 cams vs. ITR or CTR cams (Skunk2nR)
Skunk2's are expensive.....My friend was trying to talk me into stage 2's. But I'd need the retainers and springs. I had planned on Just ITR, SK2 Cams Gears, and a vafc.
Do Skunks cooperate w/ obd 2 and our 4400 and 5600 x-over and secondary runners ? Or do we have to change that w/ the vafc ?
Anyone want to buy a NOS GSR plate system, still in the box brand new? I'll let it go for $500. I think they go for around $600. I'll even throw in the cold plugs I bought.
Old Oct 1, 2002 | 05:04 PM
TimoneX's Avatar
New User
Default Re: skunk stage 1 cams vs. ITR or CTR cams (GSRdriver)
Yep Skunk2 cams are expensive. If you get the CTR/ITR cams though and decide you want more aggressive cams later, you may well regret not doing it right the first time.
What does OBDII have to do with the crossover point, or the secondary runners?
If you get any of these cams(including CTR/ITR) I think you'd benefit from a Vafc or Hondata system.
Old Oct 1, 2002 | 05:32 PM
GSRdriver's Avatar
I wasn't asking it as a whole question ( obd II and x-over and secondary ).
I may just end up getting skunk2 (1)'s, vafc, and sk2 gears.
I'm asking will you have to change the vtec x-over as you would w/ itr/ctr ?.
Old Oct 1, 2002 | 05:39 PM
TimoneX's Avatar
New User
You won't HAVE to, but I bet it gets boggy from about 4.4 to 5.2k if you don't. Looks like Skunk2 did with the dyno on their site. They don't provide much info though.
Old Oct 1, 2002 | 06:00 PM
KLN's Avatar
KLN
will you lose any power from either of these cams skunk2 [stage 1], ITR, or CTR if you keep the stock redline of a GSR?
or is it best to raise the redline to get more power from the cams?
[Modified by KLN, 3:28 AM 10/2/2002]
Old Oct 1, 2002 | 06:14 PM
TimoneX's Avatar
New User
Default Re: skunk stage 1 cams vs. ITR or CTR cams (KLN)
No I don't think you'll lose any with the stock redline. It may benefit you somewhat to increase it slightly however.
Old Oct 1, 2002 | 07:10 PM
stupidfast's Avatar
i ran the ctr cams and was not that impressed so i sold them and went with the skunks and they definately are better.. i make 6 more horse at the wheels over the ctr cam set up.. right now my car is hitting 179whp and 126ftlbs with a very mild setup.. skunks
[Modified by stupidfast69, 4:11 AM 10/2/2002]
Old Oct 1, 2002 | 07:16 PM
B18_C3P0's Avatar
Default Re: skunk stage 1 cams vs. ITR or CTR cams (stupidfast69)
if you have the money for stage 2 or 3's would you get them EVEN in a mild setup
just like bolt-ons or is there a disadvantage to getting stage 2 or 3's???
Old Oct 1, 2002 | 07:47 PM
TimoneX's Avatar
New User
Default Re: skunk stage 1 cams vs. ITR or CTR cams (B18_C3P0)
Disadvanteges are, smog, changing springs & retainers to accomodate the higher lift, & a less pleasant idle most of the time.
I'd go stage 2 or 3. I don't live in CA though. No smog testing in MI yet.
Old Oct 1, 2002 | 07:53 PM
B00ST2nR's Avatar
These Skunk2 cams keep on making power passed the Factory redline, so it would be better if you did raise it to get even more power.
Skunk2 Stage 1 cams are Smog legal and they work perfectly fine with your stock valvetrain... but if you DO raise your redline, you would need Valvesprings and retainers to keep your Valves in place when you're reving high...
Old Oct 1, 2002 | 07:57 PM
TRENDSETTLER's Avatar
skunk2ner....did you get an exhaust yet...lol
Old Oct 1, 2002 | 07:59 PM
ALLMOTOR18's Avatar
get the skunk2 stage 1......
Old Oct 1, 2002 | 08:08 PM
TimoneX's Avatar
New User
Default Re: skunk stage 1 cams vs. ITR or CTR cams (GSRTypeR)
I'd get the stage 1 if I was constantly being harassed by smog stooges. Otherwise go for the gold.
Old Oct 1, 2002 | 08:12 PM
Halo's Avatar
stage 2 and 3 would only be worthwhile if you had the compression to make them work
Old Oct 1, 2002 | 08:38 PM
b19coupe's Avatar
Running the Skunk2 Stage 2's. Idle is the same as it was with CTR cams-fine. The non-vtec lobes are a little bigger than the CTR's. One thing noticeable with the bigger cams is more valvetrain noise-but in my opinion, more power is worth a little noise.
Old Oct 1, 2002 | 11:51 PM
Mr.Integra's Avatar
Default Re: skunk stage 1 cams vs. ITR or CTR cams (b19coupe)
i never really liked skunk2 products (with the exception of their manifold)
toda A's are the best mild cam imho
Old Oct 3, 2002 | 11:26 PM
InevitableRace's Avatar
now what about skunk2 stage 1 VS crower 63402a...????
