How many washers for correcting rear camber?
I purchased 8 grade 8 washers so 2 washers for each bolt on the back. I think I remember reading 1 washer=.5* of correction. So if I have a 1.5''-1.75'' drop how many washers do I need to correct the back.
u should put either 1 or 1 1/2..u dont want the camber to be too postive...
i put two on mine..and now my tires are bumpy on the outside ...anyone know why?? blown struts maybe?
If I take off those bolts for the UCA its not going to mess up the toe is it? I read that somewhere but I thought only the compensator arm controlled toe.
QUOTE]Have the car aligned and then get the printout and see how much camber there is in the rear and go from there. [/QUOTE]
Its like you're asking us how much water to quench a thirst...
i like your bumper/tire combo.. it looks nice!!
just add 1 washer on each, and then see what happens. if you need more in about a week, add another.. trial and error mang!!!
Hahha my rear bumper looks like *** cuz when I painted it I ran out of paint so it's all splotchy and I really hate painting things.
As for washers I'll try 2 of them and see if it is still negative or positive. I have an Ingalls kit and as soon as I install that I will get it aligned. But right now I drive a lot on the highway to school so I want to make sure I don't get bad wear.
[Modified by FourthGenHatch, 4:01 AM 10/2/2002]
EJK20R
Suspension & Brakes
Mar 19, 2006 10:26 PM
Wazup
Suspension & Brakes
Apr 29, 2005 08:10 PM
spencedogg
14
Dec 7, 2003 01:14 AM
Andrew 825SM
Aug 15, 2003 03:16 AM
