all motor single cam
hi honda-tech thought i would share my build with you all
D16y8 SOHC VTEC
13.2 : 1 Endyne Pistons
JE rings
Eagle H-Beam rods
RACE Block Guard
Ported & Polished 3 Angle valve job
Manly 1mm oversized valves
Crower stage 3 NA Cam
Crower Valve spring & Titanium retainers
Custom ITB w/ velocity stacks
Neptune ECU
440 cc precision injectors
any ideas of power this thing is going to make
D16y8 SOHC VTEC
JE rings
Eagle H-Beam rods
RACE Block Guard
Neptune ECU
depends. over 170whp has been made on the crower3. depends on A LOT though.
who will be porting the head? and what header are you going to use? i wouldnt waste the money on the block guard either
i love the D series motor a lot...can put out a good amount of power on the cheap but going N/A on a D is IMO a waste of money you put a lot of money into the motor for 16-175 hp.
but back to your question....like 1.5slowmatic has said many things play a factor into a N/A car. I wouldnt be suprised you see 160
Similar setup to a customer of ours, expect his is around 11.1CR. Its a NA d16z6, 75.5mm , with nitrous CP pistons, but the same just about everything else.
Running a blox stage III cam.
We're hoping for 150-170whp on the motor, and its setup for a 150 shot.
I would expect yours to do around the same, there's too many variables to really put whp on the board though. Good luck.
Keep us posted, I have alot of guys around here wanting to get some d series work and i like to keep up with unique builds such as this.
i think all motor single cams are the ****..i wanted to try to do a little polishing and toss a cam in my f22a1 but cant seem to find anyone who does cams for an f22.
jt-sport
103
Sep 6, 2008 12:08 AM
jdm_eg94_cincy
Apr 21, 2006 08:00 PM
GSR4U2NV
14
May 25, 2005 04:16 PM
Type RS
May 15, 2004 01:21 PM
