My EF is due for a Rebuild.
Bastard motor. Here is a start..
http://www.hondahookup.com/forums/ar.../t-100455.html
Just buy a new long block instead of wasting money on a motor with no potential.
Yea all lot of people been telling me that. I plan to swap it out in the near future, but as of right now it's a daily. but please if you can give me a list i just want this car running for now since i am working on saving for the swap.
The cost of rebuilding it will be MORE than finding a good used motor.
factor in the costs of the following:
Pistons
Rings
Connecting rod bearings
Connecting rod bushings
Valve seats and seals (if needed)
Head Gasket
Main seal
Crank seal
Water Pump
Timing Belt Tensioner
Timing Belt
Senders
Intake and exhaust gaskets
other incidentals..
And then the costs of magnafluxing,boring and honing block. Crank machined for new bearings. Installing seats and guides in the head.
The costs do add up. You can do it, depending on your mechanical aptitude.
Pistons
Rings
Head Gasket
Main seal
Crank seal
Water Pump
Timing Belt
Senders
other incidentals..
Pistons
Rings
Head Gasket
Main seal
Crank seal
Water Pump
Timing Belt
Senders
other incidentals..
Pistons
Rings
Head Gasket
Main seal
Crank seal
Water Pump
Timing Belt
Senders
other incidentals..
JdmTosca
16
Aug 11, 2014 01:25 PM
cokeboat
Jul 17, 2008 08:27 AM
Speed_Ricer99
Feb 2, 2002 10:47 AM
