CA: BBS LM 18x8.5 +?? offset, Steel Grey
Old Jun 16, 2011 | 09:06 AM
j.liu's Avatar
Default CA: BBS LM 18x8.5 +?? offset, Steel Grey
****Selling for a friend, I copied and paste this from his other thread****
Got my wheels for sale...specs specified on the title...they were reverse mounted for the lower offset...tires are NOT included....the red center caps are included, some "cf-look" center caps, all AUTHENTIC, one of the caps has a broken clip but can hold using a little trick which i will show you, and some authentic BBS valve stems, new/never installed....they are still on the car...will take off once i have a buyer...pics below...price is set firm at $2100 FIRM for everything...YOU WILL NEED A MINIMUM 8MM SPACER TO CLEAR THE FRONT BREMBOS....RIMS ARE NOW OFF THE CAR AND READY FOR PICK UP....the offset is unknown....with the spacer, it is estimated to be around +15....but this is with the 8mm spacer...
(ignore the brembo part because it's for an evo)
Located in Los Angeles so Local Sale/ Pick up preferred.
Old Jun 16, 2011 | 09:43 AM
66fasty's Avatar
Default Re: CA: BBS LM 18x8.5 +?? offset, Steel Grey
bump for pics that work,my friend is looking for some LMs for his TL
Old Jun 16, 2011 | 09:46 AM
j.liu's Avatar
Old Jun 16, 2011 | 01:14 PM
j.liu's Avatar
http://i53.tinypic.com/f9hagh.jpg
Em1_Gs-R
Wheels
Nov 6, 2016 07:45 AM
mach0
Apr 1, 2009 03:34 AM
K20EF8
Wheels
Jan 7, 2009 11:23 PM
HOMESLICE
May 18, 2005 08:08 AM
