PM7 Piston/Rods,D16A1 Crank,Fuel Parts,misc...
Old Jun 16, 2011 | 07:01 AM
ZCHondaCRX91's Avatar
Default Fuel Parts,DOHC ZC Thermal Intake gasket,misc...
I'm trying to clear some room so I'm selling a few things. Everything shipped USPS Priority Mail (unless I say otherwise), and within 2 days of clear payment.
These parts are OBO, so shoot me an offer if you don't like these. Paypal only +3% or send as a gift. More pics on request. Thanks for looking.
- IAT Sensor, used worked fine. $7 shipped
- Ignition Ignitor, worked when removed, has a part number, think it's either OBD0 LS or some OBD0 D16. $10 shipped
- (2) Ignition Coils, Part number are on them, I think they are both OBD0 and either LS or some D16, worked fine when removed $10 shipped each.
- Idle/Air Valve thing? It goes in the middle of the plenum on LS and this one came off of a F23 if I remember, part number on it, $10 shipped
Old Jun 16, 2011 | 07:04 AM
Default Re: PM7 Piston/Rods,D16A1 Crank,Fuel Parts,misc...
- (2) Fuel Pressure regulators, came from LS or D16, you can see in the pics they are slightly different, both worked fine $10 shipped each or both
- Fuel pump from 87 crx, it's a basic fuel pump can be universal, don't know alot about it but worked when removed $15 shipped
- Fuel Rails, Either from LS or misc. D-series, the square one with fuel line attached is a F23 if I remember, $10 shipped
- 88-91 CRX/Civic Fuel Filter holder and fuel lines (one has the bolt drilled and tapped for fuel pressure sending unit, also has newer fuel filter) $10-$15 shipped depending on which one
- 86-89 Integra Fuel injector resistor box $10 shipped
Old Jun 16, 2011 | 07:06 AM
- (2) 88-91 DPFI Throttle body, Both are in good condition, with bad TPS other than that they worked perfect $20 shipped each
- Misc Fuel Rail ends/bolts and the spacer for fuel rail, $5 shipped for whatever
- D16A1 lower timing cover (yes for Integra DOHC ZC, no for Civic DOHC ZC) Good condition $20 shipped
- 88-91 Civic Sedan below taillight trim, dark red and perfectly straight (don't know what years it fits, but was on a 1988 ) $15 shipped
88-89 Civic Sedan center garnish, nice condition no damage but Civic sticker faded a little $30 shipped
88-95 Civic/CRX D-series black breather box, the two on the left are the same I think OBD0 and the one on the right looks different, but has same mounting points maybe OBD1? $10 shipped each or $16 shipped for all three
Universal 45 degree 3" inner diameter and 3.05" - 3.15" outer diameter aluminum pipe, has a lip on the ends like bead rolled and is very nice looking $12 shipped
Old Jun 16, 2011 | 07:32 PM
ttt
Old Jun 17, 2011 | 07:40 PM
^^^^Will be gone Saturday and Sunday, so don't expect a response until Monday.
Old Jun 20, 2011 | 08:42 AM
PM7 Pistons/rods - Sold
D16A1 Cam gears - Sold
Old Jun 21, 2011 | 08:03 AM
ttt
Old Jun 22, 2011 | 07:38 AM
ttt
Old Jun 23, 2011 | 08:14 AM
Old Jun 24, 2011 | 07:28 AM
TTT
Old Jun 25, 2011 | 07:24 AM
Will be adding pictures later
-DOHC ZC/D16A1 Intake Thermal Gasket $20 shipped
-CRX heater control valve $20 shipped
Old Jun 26, 2011 | 07:57 AM
Old Jun 27, 2011 | 08:13 AM
Old Jul 1, 2011 | 07:28 AM
^^^^^^^^^Crankshaft Sold ^^^^^^^^^^^^^^^
Old Jul 2, 2011 | 07:33 AM
ttt
slobalt77
Mid-Atlantic (Sales)
Jun 9, 2011 06:13 AM
LBR92DA-T
Jan 21, 2005 08:30 PM
B_1_8_hatch
May 21, 2003 08:32 PM
