cluster light
Old Jun 15, 2011 | 09:32 PM
chriszal1's Avatar
Default cluster light
my cluster light was not working today when i turn my car on, after 25 mins it turn on, my mph and fuel/temp gauges were working but no light, suddenly thing decided to revive and light up...any ideas on what it might be?
Old Jun 15, 2011 | 09:40 PM
Moog_enep3's Avatar
Default Re: cluster light
loose connections
Old Jun 15, 2011 | 09:57 PM
chriszal1's Avatar
Originally Posted by Moog_enep3
loose connections
i was thinking about that but from where...that will be a good question..dammit i will look at this tommorow..
Old Jun 16, 2011 | 02:06 AM
LBREF8's Avatar
or check fuses, mine was semi loose and a bump on the road got my instrument lights to work again.
Old Jun 16, 2011 | 05:23 AM
jsinher3's Avatar
check the back of the cluster, the copper film is sort of like the circuit and passes engery through everything. i know in mines i had the same problem part of the film was gone so i didnt have lights i had to run a wire from the lights on top to a fuse under the dash.
Old Jun 16, 2011 | 05:25 AM
jsinher3's Avatar
theres a pic as a refrence make sure all the copper lines are connected no cracks or peices gone
Old Jun 16, 2011 | 08:19 AM
chriszal1's Avatar
cool thank you bro, it was the fuse semi loose ,, on every bump it would move i guess. thank you all
Unphzd
Jan 13, 2011 06:42 AM
alispoon
13
Feb 27, 2006 09:09 AM
Usdmowns
Aug 1, 2005 01:57 AM
nxstrikerxn
Jul 9, 2004 08:00 PM
ef civic
Oct 19, 2003 10:55 AM
