help have 1994 honda accord stalls at sop sign when air on
Old Jun 15, 2011 | 05:53 PM
crazycabana's Avatar
Icon2 help have 1994 honda accord stalls at sop sign when air on
ok here is the problem i have a 1994 honda accord has recently within last 3 months had tune up been running great had air conditioning recharged and it started stalling when you stop always starts right back up. also when idling in park i noticed the temp hand went up to above half way mark has never done that before and the air was on. when air off was running great this started last week now today it has been stalling more and even stalling when the air is off any advice
Old Jun 15, 2011 | 06:05 PM
phootbag's Avatar
Default Re: help have 1994 honda accord stalls at sop sign when air on
Your system could be overpressurizing if both condensor fans aren't running with the A/C on. This could causes stalling and overheating.
Old Jun 15, 2011 | 06:06 PM
nus_dogg's Avatar
Check that both the fans behind the radiator are working when you have A/C on. At idling if the radiator fan doesn't work, it'll get hotter while it's idling; thus, overheat.
Old Jun 15, 2011 | 06:09 PM
slomofo's Avatar
GDD Member
Does it shake a little bit before it stalls?
Old Jun 16, 2011 | 09:51 AM
chikin pickle's Avatar
There is an over/under pressure cutout on the compressor.
I would look into something unrelated to the a/c. Sounds like you have engine troubles.
Old Jun 16, 2011 | 10:03 AM
its not overheating when it stalls the only time the temp went up was when it was in park at store with air on for about 15 minutes then the hot hand went up above halfway mark so i cut the car off.and now it stalls even with air off when you slow down to stop and the rpm drop way low.and it does shake just a little prior to stalling.but starts right back up.
Old Jun 16, 2011 | 10:06 AM
i would think something to do with the air since it never did this until we recharged air
Old Jun 16, 2011 | 10:57 AM
phootbag's Avatar
That may be. However, I have personally diagnosed stalling complaints due to an overpressurizing system caused by a faulty condensor fan. I stand by my suggestion for a possible cause to this persons symptom.
Tomthumb4000
Aug 12, 2018 04:06 PM
Atalbot20
Mar 31, 2018 09:32 AM
debbieyakiwchuk
Jul 27, 2017 04:27 PM
Tee Miles
Dec 14, 2013 12:00 AM
chrispaul
Jun 8, 2004 11:54 AM
