F/S Skunk2 Tuner 3
These camshaft specifications are the recommended settings. It is the responsibility of the engine builder to check all clearances. For optimum power, the vehicle must be dyno tested and tuned to accommodate for each individual engine setup.
Camshaft Specifications:
Intake:
272°/12.8 @ 1mm / 0.000” lash
Exhaust:
280°/11.9 @ 1mm / 0.000” lash
Other Recommended Camshaft Specifications:
Intake:
Opening:35° BTDC
Peak Lift:100° ATDC
Closing:52° ABDC
Exhaust:
Opening:62° BBDC
Peak Lift:105° BTDC
Closing:32° ATDC
Tappet Clearance:
Intake: 0.007” (cold)
Exhaust: 0.008” (cold)
source:http://www.skunk2.com/installation/305-05-0150.pdf
Intake:
Exhaust:
Intake:
Opening:35° BTDC
Peak Lift:100° ATDC
Closing:52° ABDC
Exhaust:
Opening:62° BBDC
Peak Lift:105° BTDC
Closing:32° ATDC
Tappet Clearance:
