need help
Old Jun 14, 2011 | 06:19 PM
jerzeyjoe's Avatar
Default need help
ok i have a 88 si crx that has a d15b with a z6 head car is turboed i just put a headgasket on and now it wont start.it turns over the fuil pump dosnt kick on and its not getting sprak.everything is pluged in the way it was
Old Jun 15, 2011 | 03:25 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: need help
Ok...??? Do some of the basic checks - if you did a head gasket you should be able to check your grounds, triple check connections, is your battery in the car correct, all fuses good, ect... Essentially what you did shouldn't cause your fuel pump to not prime. So get that fixed and go from there.
Old Jun 15, 2011 | 12:49 PM
jerzeyjoe's Avatar
did all them 3times still nothing its nuts
Old Jun 15, 2011 | 01:07 PM
4drEF's Avatar
Keyboard Humorist
You changed the headgasket and now it won't spark and fuel pump won't kick in.
I'm assuming you mean that the fuel pump doesn't even prime when you turn the key to ON and not even try to start it.
This really really really sounds like your ground lugs at the thermostat housing are disconnected.
Old Jun 15, 2011 | 01:18 PM
jerzeyjoe's Avatar
ill look at it and the car turns over just wont start
Old Jun 17, 2011 | 04:18 PM
jerzeyjoe's Avatar
the grounds are good just put a new main relay and still wont start
DA9b0y303
29
Aug 21, 2013 03:51 PM
teg racer 877
Mar 5, 2009 05:40 PM
allmotor2.1
Nov 21, 2007 05:45 AM
Soccerking3000
12
Dec 21, 2005 06:10 PM
