94 GSR block half shaft stripped
Old Jun 14, 2011 | 04:21 PM
t-del28's Avatar
Post 94 GSR block half shaft stripped
whts up ht...its been awhile to get on ht ha
i own a 94 gsr and i accidentally over tight the 3 bolts for the half shaft on the block which its came out as stripped =(....
so im wondering if can do Heli-Coil Insert with the thread fixed??
but can do it by under the vehicle while doing that???
Old Jun 14, 2011 | 09:12 PM
t-del28's Avatar
Default Re: 94 GSR block half shaft stripped
come on y'all, its okay if anyone dont understand wht im tryin to explain, please let me know....
bump
Old Jun 14, 2011 | 10:05 PM
mark@silbernage's Avatar
I don't know objectively. I didn't seem like they torque on those bolts is so high that heli-coils wouldn't work.
The three bolts are 10mm with 1.25mm thread pitch - torqued to 29ft-lbs. Doesn't seem like you're going to rip out a coil that large in diameter with only 29ft-lbs.
OTOH, what choice do you have? It's *way* cheaper than a new block...
Mark
Old Jun 14, 2011 | 10:06 PM
As for doing this in-vehicle, perhaps. I'd check with a local machine shop - they love to talk... who knows, a cold-one may go a long way!
Old Jun 15, 2011 | 11:02 AM
t-del28's Avatar
Post Re: 94 GSR block half shaft stripped
Mark
yea, u r correct abt the bolts but im thinkin to get the motor remove and let it stand on straight vertically which i could try to re tap and insert heli-coils to fixed the thread...
if i would go to the local machine shop and will cost me more $$ on labor, so im not sure yet
i dislike the 3 hex bolts on the block for half shaft because they r not really strong enough
Old Jun 16, 2011 | 09:20 AM
t-del28's Avatar
does it happen to you anyone before? wht r the steps you had got it fixed?
best way is to remove the motor and re tap evenly??
bump
Old Jun 16, 2011 | 10:17 AM
They make a jig for hand drills that hold them square to the surface being drilled, which might work if the surface of the block is flat there (don't recall).
sammyb20
Mar 1, 2009 07:30 PM
slowteg90
Sep 6, 2007 04:20 PM
User 42624
Jun 7, 2006 10:48 PM
StreetRacinThug
Mar 27, 2006 09:29 AM
BoostedH23Accord
Mar 6, 2004 10:02 AM
