Shaving my badges and emblems
Old Jun 14, 2011 | 09:51 AM
TYLER3's Avatar
Icon2 Shaving my badges and emblems
Hey I'm taking all of the Acura badges off my teg and gonna shave all of the holes that aren't needed anymore. Also going to shave the engine bay because I took AC, ABS, cruise and someother stuff out and want to make it look clean. So I went and picked up paint first at a body shop and they made me a pint of brush on and an aerosol can. So since all the holes I'm filling are small i was thinking of using glaze putty to fill them and then sand them and paint. I was wondering if there were any better ways to do this?
Old Jun 14, 2011 | 11:21 AM
mouab18c1's Avatar
Default Re: Shaving my badges and emblems
whats glaze putty? You can either weld them shut and grind it down or use body filler. For bigger holes I would weld it shut first.
Old Jun 14, 2011 | 03:24 PM
TYLER3's Avatar
its kinda like bondo but better and they are really small holes os i'll probably use the body filler.
Old Jun 14, 2011 | 10:58 PM
ninjaturtleEG's Avatar
Glazing putty is too thin. That stuff is used to fill pinholes over body filler and tiny dents. When you are filling holes you should have some sort of backing before you put any kind of filler over it so the filler has support in the back and something to adhere to otherwise the filler will just crack over time.
Old Jun 15, 2011 | 11:03 AM
TYLER3's Avatar
Well yeah so the trunk and engine bay I can do with a welder but what can I do with the front bumper?
Old Jun 15, 2011 | 11:14 AM
hondad6's Avatar
Fiberglass on the back and fiberglass resin on the front. Build it up a little and sand smooth with high grit sand paper once it is dry.
Old Jun 15, 2011 | 11:29 AM
TunerN00b's Avatar
Plastic welding, of course.
amrussellusn
Paint and Body
Oct 7, 2012 03:13 PM
-16V-
Paint and Body
Mar 15, 2009 06:35 PM
serious
Dec 12, 2002 02:07 PM
integration
Sep 22, 2002 10:25 AM
