fs-ft 88 crx hf
Was guys and gals I have a 88 hf for sell that used to be my baby it has a d16z6 with 160*** miles on a Si tranny converted it to obd1 on a p28 has a 90-91 conversion front end side moldings and dash, interior was blue but now its black. Has a innovative crossmember skunk 2 front camber kits da front brakes with drilled and slotted rotors earls steel brake lines all The way around have rear disk breaks but haven't installed new driver axle new brake pads painted 2 years ago now for the cons salvage title doesn't run at the moment the main relay is shot needs throttle cable need to hook up the radiator no seats gutted in the back need to wire vtec and 4 wire o2 sensor but should run like a champ 1200 firm hmu if interested thanx
http://i1215.photobucket.com/albums/...-32-30_834.jpg
http://i1215.photobucket.com/albums/...-19-36_655.jpg
http://i1215.photobucket.com/albums/...-32-44_347.jpg
http://i1215.photobucket.com/albums/...-20-36_853.jpg
http://i1215.photobucket.com/albums/...-20-02_326.jpg
http://i1215.photobucket.com/albums/...-20-49_469.jpg
No actually I bought a gsr motor from sum dude that turned out to be stolen so I got pulled over and they took my car ripped out the motor and my LSD j1 :'( so the writing is from the chp
If the problem is what you say then fix the car for 40 bucks and sell it relay 10 throttle cable 15 and wiring up stuff is free hook up the radiator imo u should get it running to prove it runs
whiteguyndahood
Sep 22, 2007 12:10 PM
