Replacing piston rings in jdm 96 spec type r
Old Jun 13, 2011 | 06:33 PM
milanoitr's Avatar
Icon2 Replacing piston rings in jdm 96 spec type r
Whats up h-t.im going to be replacing my rings this weekend and have a few questions.yes I did search..i wanna get oem rings from honda,will the usdm type r rings work?? What are the ring gaps on the jdm type r? And I heard alot about positioning the ring gaps in a certain place how do I put them?? Ive been working on hondas for a few years so I know I can do it myself just want to get everything figured out first before I start tearing my motor apart...help is greatly appreciated.the reason why im doing this is cuz im going through like a qt of oil a day (i know its alot) ive changed my valve seals with no luck valve guids and seats looked good.changed head gasket and pcv valve no luck eaither my car smokes like a freigt train when accelerating and like I said burns oil like crazy and I have no leaks.so last thing on my list is rings my compression is 265 accross the board when motor is cold but ive been hearing that my compression rings are good but my oil rings can be shot.sorry for the long post just wanna figure this out.car is stock just header and fuel rail its also tuned thnx in advance
Old Jun 13, 2011 | 07:03 PM
milanoitr's Avatar
Default Re: Replacing piston rings in jdm 96 spec type r
Anybody??c'mon I need some advice and answers from all the honda genuise's or howecer you spell it lol
Old Jun 13, 2011 | 07:21 PM
racebum's Avatar
there is no difference in the setup between usdm and jdm. just follow the book, actually have someone who's built a bottom end before help you. make sure you measure the cylinders for out of round and you should pay the machine shop for an actual hone. does a better job than the brush and drill
Old Jun 13, 2011 | 07:47 PM
milanoitr's Avatar
Thnx for the reply..i know I can do it by myself I just want all the correct numbers so I dont screw up on it.i can go buy a helms but im tight on money and dont wanna spend 70 bucks on one I know someone has to have the answer to my questions on here lol..
Old Jun 13, 2011 | 08:35 PM
milanoitr's Avatar
Ttt... c'mon guys and gals
Old Jun 14, 2011 | 02:49 AM
milanoitr's Avatar
Going to work bump
Old Jun 14, 2011 | 03:49 AM
d=f20c1's Avatar
helms manual is free, no need to buy it.
i think its:
(link removed)
go to the manuals section
Last edited by Dogginator; Jun 14, 2011 at 07:42 AM. Reason: Sadly, we cannot post those links.
Old Jun 14, 2011 | 07:45 AM
Dogginator's Avatar
Daisy... Daisy...
OP, keep in mind that many were at Expo the past few days.
Did you perform a leakdown test? Does it burn oil all of the time or just on startup?
Old Jun 14, 2011 | 04:57 PM
milanoitr's Avatar
I havent done a leakdown test yet..and it burns oil constily ill be full on oil drive across town come back and it will be low it smokes like crazy only when im on it but even if I just cruise it still blows through oil..i replaced the valve seals didnt replace seats or valve guides cuz they looked good..like I said b4 my compression was 260 265 across wen motor was cold hard to believe its my rings but what else can it be...car runs stong no problems at all besides the smoking and oil loss and I dont have any oil leaks so thats not my problem..it is straight pipe with no cat or resonator so I should expect a little smoke but its no where near little.smoke looks blue when im driving but on the dyno it was more of a greyish black.but blue means oil and im losing it so idk its driving me nuts.any help is appreciated.
Old Jun 14, 2011 | 05:59 PM
Dogginator's Avatar
Daisy... Daisy...
That is almost certainly rings.
Old Jun 14, 2011 | 06:23 PM
milanoitr's Avatar
yea thats what im thinking to ill do it and if its not the problem atleast ill have new rings..but I still need to know the ring gap for the jdm itr I went to that link but there was nothing for a type r so if anyone has the numbers for the ring gap can you please let me know thanks for the replys guys....
Old Jun 14, 2011 | 08:49 PM
01-0720's Avatar
From Helms Manual:
For B18C5 block:
Top ring end gap: Standard 0.008-0.014 Service Limit: 0.024
Second ring end gap: Standard 0.016-0.022 Service Limit: 0.028
Oil ring end gap: Standard 0.020-0.028 Service Limit: 0.028
Old Jun 14, 2011 | 09:25 PM
milanoitr's Avatar
Cool thanks everyone one more thing do I gap the oil spacer ring the same as the oil ring??
Old Jun 15, 2011 | 02:59 AM
milanoitr's Avatar
Ttt
Old Jun 16, 2011 | 03:40 PM
milanoitr's Avatar
Ok so I called the stealership and they want like 42.00 bucks per piston for the rings...so I called a local place and I can get hastings or npr rings for way cheaper..my question is do I still use the oem ring gap specs or the gap specs from the hasting or npr rings?????
Old Jun 16, 2011 | 03:53 PM
01-0720's Avatar
Don't be cheap man, these are important, buy oem, do a little shopping around im sure you can find the oem cheaper
Old Jun 16, 2011 | 04:06 PM
milanoitr's Avatar
I dont wanna cheap out but I live in bakersfield ca and there aint **** her unless I drive for hrs...i did some research on those rings and heard that they were pretty good and work realy well...just need to stop my car from smoking like a traing and going through a court of oil like every 50 miles
Old Jun 16, 2011 | 04:17 PM
milanoitr's Avatar
So do I I use the oem specs or the specs that come with the rings?????
Old Jun 16, 2011 | 05:02 PM
Dogginator's Avatar
Daisy... Daisy...
Look for an online Acura parts dealer. Delray is one.
http://www.acuraoemparts.com/
Old Jun 16, 2011 | 05:35 PM
milanoitr's Avatar
I cant get stuff online I dont have a credit card im a broke *** lol
Old Jun 16, 2011 | 06:36 PM
racebum's Avatar
if you don't even have a checking account or debit card you have bigger problems than this
Old Jun 16, 2011 | 07:11 PM
milanoitr's Avatar
Im waiting on my direct deposit to kick in and this is my only car im not going to keep driving it like this I rather just get it fixed asap instead of ****ing it up anymore u feel me
Old Jun 16, 2011 | 07:39 PM
01-0720's Avatar
you can get visa gift cards and you can use them online to purchase parts, goto a cvs or a walgreens or 7-11
Old Jun 16, 2011 | 08:11 PM
milanoitr's Avatar
Old Jun 17, 2011 | 02:33 PM
milanoitr's Avatar
Ok so I got the hasting rings and it says to gap the top ring .004 for every I.ch of the cylinder but doesnt say anything about the second ring and oil rings so what do I gap those to???
