FS: Brand New Catch Can Custom, cheap!
Old Jun 13, 2011 | 02:33 PM
signature sound's Avatar
Default FS: Brand New Catch Can Custom, cheap!
EDIT: To clear up the confusion, PLEASE read the text below. I make these tanks individually with the fitting size you choose, fitting color you choose, tank color of choice and mounting location choice. The fittings size, quantity and type all play a role on how much the over all cost will be. Shipping is calculated and will also determine overall price so please include your zip when requesting a quote. I can provide hoses, and so does eBay. If you want me to provide a hose "KIT", I need to know specifics like length and size and type to accurately quote it for you. I will also need SPECIFICS on hose ends for example angle, color and so on...
PLEASE READ:
Heres my creation for a crank case ventilation system. No need to relocate the battery, no need to take out a loan to afford it, customize your fitting colors and sizes, expandable and affordable.
One tank is good for 300 to 400 whp. Add a second tank when you crank the boost later on for up to 800 whp. Custom triple kits also available. The system grows as you need by simply adding a tank as you need.
For an example: Black tank, two AN-10 fittings, petcock drain, stainless mounting bolts and nuts, breather filter top: $65 plus shipping.
Here are some examples: (keep in mind that each tank is purpose built. Some can have a check valve to eliminate the stock PCV, some can have breather filters. I have made them for several different cars, trucks and bikes; BMW, Mazda, Honda, Harley, Dodge, and so on...)
This style tank is an open element breather with dual AN-10 male flares. The OPTIONAL fitting on bottom was installed instead of the drain. This allows the tank to recirculate. This specific tank sold for $99. The high shine polish upgrade is what made it a little more pricey.
Old Jun 13, 2011 | 02:36 PM
Default Re: FS: Brand New Catch Can Custom, cheap!
Here it shows the tank installed in a great spot. Away from heat. This car is a repeat customer from The Netherlands. He does circuit racing out there and said the tank is working great and cost much less than his previous one.
Old Jun 13, 2011 | 02:38 PM
Below is an example of all the different tanks customers have requested in the past. Hopefully its gives an idea of all the ways you can have yours configured.
Old May 9, 2012 | 08:05 PM
Old May 9, 2012 | 08:07 PM
Old May 9, 2012 | 08:10 PM
Old May 10, 2012 | 01:57 PM
0487erasmo's Avatar
Originally Posted by signature sound
How much for this?
0487erasmo's Avatar
pm me
Old May 10, 2012 | 07:42 PM
Originally Posted by 0487erasmo
How much for this?
that one is made of stainless steel. Its a smaller unit with a 7" total height and 3" diameter. It has AN-6 fittings, but you can custom order any size up to AN-10. Or if ou want barbs I can go up to 1". That tank sold for $65. The only thing you dont see in the photo is the mounting studs that were added to it.
Old May 13, 2012 | 10:46 AM
spAdam's Avatar
Loved
Community Favorite
Thanks for the can. Breaking in the motor now.
Old May 13, 2012 | 10:57 AM
Looks good. Were u able to use the bracket I provided?
Old May 13, 2012 | 02:22 PM
spAdam's Avatar
Loved
Community Favorite
Yeah. I actually attached it to the bracket that I fabbed there so I can loosen the bolts and slide it off to empty.
Old May 13, 2012 | 05:04 PM
DaBEast's Avatar
Pmed!!!!!
Old May 13, 2012 | 06:36 PM
FIRST POST UPDATED!!!
Thanks for all the PM's guys. I think I got to them all. If you have any more questions, please feel free to ask.
NMZ
Sep 6, 2010 04:37 PM
NMZ
May 16, 2010 01:37 PM
SiR HatchAlot
Nov 29, 2004 01:56 PM
