GSR 80mph at 3500k RPMS!?
Old Jun 12, 2011 | 03:43 PM
mdrshewrote's Avatar
Default GSR 80mph at 3500k RPMS!?
Hey guys just getting worried here, I recently put a GSR swap in my del Sol. Only difference is I am using a chipped P28 and also using my stock Single Cam cluster if that reads correctly? my GSR trans VIN says DC2 also on it...should I be worrying? The mechanic told me it was a GSR trans but it feels like a LS cause 3rd takes a very long time to hit 8K. Any help if it's normal or theres something wrong?
- Thanks!
__oversea's Avatar
Default Re: GSR 80mph at 3500k RPMS!?
normal.
Old Jun 12, 2011 | 03:47 PM
Hrmm all my researches is saying 5th gear, LS=3500k @ 80mph. GSR 4000k @ 80mph. Maybe i'm just worrying too much...
Old Jun 12, 2011 | 03:50 PM
1SLW4DR's Avatar
Ya if your at 3500 at 80 then you have an LS trans. My buddy's GSR sat at 4k when doing 80 so unless you both have jacked up gauge clusters then you need to get your money back.
Old Jun 12, 2011 | 03:51 PM
vtaker's Avatar
that is correct. sounds like you have an LS trans. much better for cruising on the hwy. 80mph and 4k in my GSR just eats fuel like crazy.
Old Jun 12, 2011 | 04:51 PM
1998GsRIntegra's Avatar
Lets not rule out the possibility of having a gsr trans with an ls fifth gear. Its not to uncommon for people to do that now a days since a gsr fifth puts you at near 4k or over cruising on the highway.
Old Jun 12, 2011 | 05:16 PM
I don't believe my mechanic threw on a LS 5th gear. He told me it was a full GSR swap besides he kept my P28 and chipped it. I read that if the VIN says DC2 then its a GSR?
Old Jun 12, 2011 | 10:00 PM
vtaker's Avatar
alright well then give us the mph in some other gears.
Old Jun 13, 2011 | 07:23 AM
Will do.
Old Jun 13, 2011 | 10:12 AM
TOO MUCH TORQUE's Avatar
integra LS @ 80 mph runs at 3,500 rpms. GSR is 4k. just drove over 900 miles of highway on my LS, so i know
Old Jun 13, 2011 | 07:46 PM
turboskratch's Avatar
My GSR trans runs 80mph at 5th.
Old Jun 13, 2011 | 08:04 PM
honda250r&crx's Avatar
lol I wish mine ran that low. I have a b16 tranny its runs 3500 rpm at 60 mph.
Old Jun 17, 2011 | 05:00 AM
mhax's Avatar
- Thanks!
Just looked this morning, and my gsr is doing 80mph at 4000 rpm. Now since you swapped it in a del sol, i think, maybe, the shape of the car (front area for drag coefficient) and the weight (friction of tire on the road) could affect the speed you are doing for a specific rpm.
Old Oct 26, 2012 | 01:47 PM
civicguy395's Avatar
the only thing there that would make a different in rpm is tire height and unless ur running like some 35x10x50s or something its not gunna make much of a difference not enough to get u pulled over anyways
Old Oct 26, 2012 | 01:57 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
My GSR tranny in my 94 civic VX( light *** car) runs between 3500-4000 RPM's at 80mph. If I am on a level surface and maintaining 80 mph (hardly any load on throttle) than it is closer to 3500'ish rpm's. If I have more of a load on my throttle going up and down hills it is closer to 4,000 rpms. At 4,000 rpm's I am running close to 85mph.
I am also running on 205/50/15 dunlop z1 star specs and I am told those run a little larger than the typical 205/50's.
Old Oct 26, 2012 | 01:58 PM
sounds like your clutch is slipping or its automatic with a kickout torque converter
Old Oct 27, 2012 | 12:02 PM
DeCePtEgRa's Avatar
My 91 ls with an a1 at 80mph rpm is 3800-3900 or just before 4000. My Speedo is off by 2-3 mph also.
Old Oct 27, 2012 | 02:17 PM
I see no one has noticed the dates in this thread yet. Y'all are about a year and a half late. Leave it to a new user to...
Old Oct 27, 2012 | 02:32 PM
DeCePtEgRa's Avatar
How very observant you get a gold star next to your name lol
Old Oct 27, 2012 | 02:39 PM
Lmao
Old Apr 6, 2013 | 09:09 AM
b20bFourDoorCivicLX's Avatar
<--b20b Gsr Tranny - I travel at 80 mph in 5th gear at 4000.
I have to owned a LS tranny let me tell you. IT SUCKS, yea its more easy to drive less noise, but if your like me and want to feel the torque of my 2.0 stick with a GSR
Old Apr 6, 2013 | 09:39 AM
After fixing a bad cluster my gsr runs 80mph at 4k rpm.
Old Apr 6, 2013 | 08:31 PM
Blackhalo6's Avatar
lol bringing back an old dead thread a second time! fun fun.
Old Apr 6, 2013 | 11:15 PM
m4xwellmurd3r's Avatar
I love how someone posted that the aero of the car could make it look like it's doing 80mph at 3500rpm, then someone posted that the tiresize would be the only way to change the speed at certian rpm
Then failed to realize that the speedo is calibrated for a certian tire size. You could put 30 inch tall tires and it would still say 80mph at 3500 rpm, but you'd be going closer to 90mph in reality!
necroing threads is fun
Old Apr 7, 2013 | 10:41 AM
Marvin1985's Avatar
At 80mph in 5th
Gsr: 4000rpms
LS: 3500rpms
B16: 4600rpms<- this is my buddy's trans with LSD on a poormans type r
