Brake Hose to Shock Hardware
Good Day Folks
I just bought a KYB Ground Controll Eibach kit. Its the race version and does not have the mounting points to bolt the brake lines to the shocks. How is this done? Is there a bracket I can buy?
Thanks
Thanks
Doesn't the brake line bracket help keep the strut seated at the proper level in the fork?
No, the brake line mount is only to mount the brake line and is higher than where the shock meets the shock fork.
Zip ties are used in most instances where there's no tab.
If you look closely at your shocks there's a notch for where the pinch bolt of your fork will line up in, its when your lined up with that notch you can properly torque the bolt.
My brake line attaches to the knuckle.
I do not see how that makes the added ring bear weight. It would almost have to be welded, or otherwise fixed to the shock. It would also have to exactly align so that it could bear some of the load with the notch and bolt. I have shocks withoiut rings and the work fine. I initially was concerned until I understood that the shock is seated when the bolt goes through the notch. The ring may have a brakeline attachment, otherwise not used.
fireant
May 4, 2005 06:47 AM
VTECAcuraGSR
12
May 2, 2005 08:02 PM
